[MOAB-dev] commit/MOAB: danwu: Minor update on the doxygen comments (to generate h5mmain.html) inside mhdf.h, line 73. It should be: The four sub-groups ...
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Wed Jul 31 13:53:39 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/ef302c38fc4c/
Changeset:   ef302c38fc4c
Branch:      master
User:        danwu
Date:        2013-07-31 20:53:26
Summary:     Minor update on the doxygen comments (to generate h5mmain.html) inside mhdf.h, line 73. It should be: The four sub-groups ...
Affected #:  1 file
diff --git a/src/io/mhdf/include/mhdf.h b/src/io/mhdf/include/mhdf.h
index 9a7a478..db36d63 100644
--- a/src/io/mhdf/include/mhdf.h
+++ b/src/io/mhdf/include/mhdf.h
@@ -70,7 +70,7 @@ extern "C" {
  * type of sufficient size to accomodate the entity IDs.
  * The \c tstt group contains four sub-groups, a datatype object, and a
- * dataset object.  The three sub-groups are: \c nodes, \c elements,
+ * dataset object.  The four sub-groups are: \c nodes, \c elements,
  * \c sets, and \c tags.  The dataset is named \c history .
  * The \c elemtypes datatype is an enumeration of the elem topologies
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
