[MOAB-dev] commit/MOAB: iulian07: use \image for included figures
    commits-noreply at bitbucket.org
    Tue Jul 30 13:09:26 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8018f9a7138b/
Changeset:   8018f9a7138b
Branch:      master
User:        iulian07
Date:        2013-07-30 20:07:01
Summary:     use \image for included figures
according to doxygen documentation, the \image command and IMAGE_PATH
should be used to specify the location of figures.
doxygen will then copy the files in the html folder
Affected #:  2 files
diff --git a/doc/DG/moabDG.h b/doc/DG/moabDG.h
index ed23052..32d7fe1 100644
--- a/doc/DG/moabDG.h
+++ b/doc/DG/moabDG.h
@@ -29,7 +29,7 @@
   \section sequence  EntitySequence & SequenceData
   \subsection figure1 Figure 1: EntitySequences For One SequenceData
-   <img src="../DG/figure1.jpg">
   \ref dg-figures "List of Figures"
@@ -108,7 +108,7 @@ enforces the following four rules on its contained data:
   \subsection figure2 Figure 2: SequenceManager and Related Classes
-   <img src="../DG/figure2.jpg">
@@ -187,7 +187,7 @@ than is required at a given time for contained objects.
 - MeshSet
   \subsection figure3 Figure 3: SequenceManager and Related Classes
-    <img src="../DG/figure3.jpg">
diff --git a/doc/user.dox.in b/doc/user.dox.in
index adb22ef..07f707f 100644
--- a/doc/user.dox.in
+++ b/doc/user.dox.in
@@ -359,7 +359,7 @@ EXAMPLE_PATTERNS       =
 # directories that contain image that are included in the documentation (see
 # the \image command).
-IMAGE_PATH             =
+IMAGE_PATH             =  @top_srcdir@/doc/DG/
 # The INPUT_FILTER tag can be used to specify a program that doxygen should
 # invoke to filter for each input file. Doxygen will invoke the filter program
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
