[MOAB-dev] commit/MOAB: tautges: Improving comments and a bit of code.
commits-noreply at bitbucket.org
Mon Jul 29 10:12:06 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/ef18d29a14eb/
Changeset: ef18d29a14eb
Branch: master
User: tautges
Date: 2013-07-29 17:11:58
Summary: Improving comments and a bit of code.
Affected #: 2 files
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index 348bad0..90bab23 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -6894,12 +6894,10 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
// take all shared entities if incoming list is empty
Range entities;
- if (entities_in.empty()) {
+ if (entities_in.empty())
std::copy(sharedEnts.begin(), sharedEnts.end(), range_inserter(entities));
- else
- entities = entities_in;
+ else entities = entities_in;
int dum_ack_buff;
for (ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); sit++, ind++) {
@@ -6910,7 +6908,7 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
result = filter_pstatus(tag_ents, PSTATUS_SHARED, PSTATUS_AND, *sit);
RRA("Failed pstatus AND check.");
- // remote nonowned entities
+ // remove nonowned entities
if (!tag_ents.empty()) {
result = filter_pstatus(tag_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT);
RRA("Failed pstatus NOT check.");
@@ -6998,7 +6996,10 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
assert(src_tags.size() == dst_tags.size());
if (src_tags != dst_tags) {
std::vector<unsigned char> data;
- Range owned_ents(entities_in);
+ Range owned_ents;
+ std::copy(sharedEnts.begin(), sharedEnts.end(), range_inserter(entities));
+ else owned_ents = entities_in;
result = filter_pstatus(owned_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT);
RRA("Failure to get subset of owned entities");
diff --git a/src/parallel/moab/ParallelComm.hpp b/src/parallel/moab/ParallelComm.hpp
index c558334..55bdd93 100644
--- a/src/parallel/moab/ParallelComm.hpp
+++ b/src/parallel/moab/ParallelComm.hpp
@@ -291,26 +291,38 @@ namespace moab {
/** \brief Exchange tags for all shared and ghosted entities
* This function should be called collectively over the communicator for this ParallelComm.
* If this version is called, all ghosted/shared entities should have a value for this
- * tag (or the tag should have a default value).
- * \param tags Vector of tag handles to be exchanged
+ * tag (or the tag should have a default value). If the entities vector is empty, all shared entities
+ * participate in the exchange. If a proc has no owned entities this function must still be called
+ * since it is collective.
+ * \param src_tags Vector of tag handles to be exchanged
+ * \param dst_tags Tag handles to store the tags on the non-owning procs
+ * \param entities Entities for which tags are exchanged
ErrorCode exchange_tags( const std::vector<Tag> &src_tags,
- const std::vector<Tag> &dst_tags,
- const Range &entities);
+ const std::vector<Tag> &dst_tags,
+ const Range &entities);
- * This function should be called collectively over the communicator for this ParallelComm
+ * This function should be called collectively over the communicator for this ParallelComm.
+ * If the entities vector is empty, all shared entities
* \param tag_name Name of tag to be exchanged
ErrorCode exchange_tags( const char *tag_name,
* \param tagh Handle of tag to be exchanged
ErrorCode exchange_tags( Tag tagh,
/** \brief Perform data reduction operation for all shared and ghosted entities
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
