[MOAB-dev] commit/MOAB: tautges: Adding MPI_Reduce on max delta and reporting interval.
commits-noreply at bitbucket.org
Mon Jul 29 09:44:11 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/c250e4f568b6/
Changeset: c250e4f568b6
Branch: master
User: tautges
Date: 2013-07-29 16:44:01
Summary: Adding MPI_Reduce on max delta and reporting interval.
Affected #: 1 file
diff --git a/examples/LloydRelaxation.cpp b/examples/LloydRelaxation.cpp
index 5c9321e..0cf9d1e 100644
--- a/examples/LloydRelaxation.cpp
+++ b/examples/LloydRelaxation.cpp
@@ -26,15 +26,17 @@
using namespace moab;
using namespace std;
-string test_file_name = string(MESH_DIR) + string("/surfrandomtris.g");
+string test_file_name = string(MESH_DIR) + string("/surfrandomtris-4part.h5m");
#define RC if (MB_SUCCESS != rval) return rval
-ErrorCode perform_lloyd_relaxation(ParallelComm *pc, Range &verts, Range &cells, Tag fixed, int num_its);
+ErrorCode perform_lloyd_relaxation(ParallelComm *pc, Range &verts, Range &cells, Tag fixed,
+ int num_its, int report_its);
int main(int argc, char **argv)
int num_its = 10;
+ int report_its = 1;
MPI_Init(&argc, &argv);
@@ -80,7 +82,7 @@ int main(int argc, char **argv)
rval = mb->tag_set_data(fixed, skin_verts, &fix_tag[0]); RC;
// now perform the Lloyd relaxation
- rval = perform_lloyd_relaxation(pcomm, verts, faces, fixed, num_its); RC;
+ rval = perform_lloyd_relaxation(pcomm, verts, faces, fixed, num_its, report_its); RC;
// delete fixed tag, since we created it here
rval = mb->tag_delete(fixed); RC;
@@ -96,7 +98,8 @@ int main(int argc, char **argv)
return 0;
-ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &faces, Tag fixed, int num_its)
+ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &faces, Tag fixed,
ErrorCode rval;
Interface *mb = pcomm->get_moab();
@@ -185,14 +188,25 @@ ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &fac
mxdelta = std::max(delta, mxdelta);
for (f = 0; f < 3; f++) vcentroids[3*v+f] = vnew[f];
+ // set the centroid tag; having them only in vcentroids array isn't enough, as vertex centroids are
+ // accessed randomly in loop over faces
rval = mb->tag_set_data(centroid, owned_verts, &vcentroids[0]); RC;
- cout << "Max delta = " << mxdelta << endl;
// 2c. exchange tags on owned verts
if (nprocs > 1) {
rval = pcomm->exchange_tags(centroid, shared_owned_verts); RC;
+ if (!(nit%report_its)) {
+ // global reduce for maximum delta, then report it
+ double global_max = mxdelta;
+ if (nprocs > 1)
+ MPI_Reduce(&mxdelta, &global_max, 1, MPI_DOUBLE, MPI_MAX, 0, pcomm->comm());
+ if (1 == nprocs || !pcomm->rank())
+ cout << "Max delta = " << global_max << endl;
// write the tag back onto vertex coordinates
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
