[MOAB-dev] Bug in kdtree?
    Tim Tautges
    tautges at mcs.anl.gov
    Fri Jul 26 07:52:52 CDT 2013
On 07/25/2013 05:14 PM, Iulian Grindeanu wrote:
>     so the entities come out ordered according to the distance only if the max_ints is set.
>     (only the first max_ints are returned, with the closest distance from the source of the ray)
>     The bug is fixed now.
>     So do you think that we should order them in all cases, for consistency?
Yes.
> then we should order them also for OBB tree. Do we have other trees with ray intersecting capability?
Yes.  But, let's wait until I push all the changes on tree redesign before doing that.
- tim
>     That makes sense.
>     Iulian
>         I do think the entries should be ordered at the end of the call, after tree traversal is done, though.
>         - tim
>         On 07/24/2013 04:35 PM, Iulian Grindeanu wrote:
>          > the bug is around that logic, that I try to understand.
>          > It seems that the "ray_end" is reset, which is why some points are missed.
>          > I didn't write that logic, maybe Tim or Paul know who did.
>          > I don't think we should guarantee the order;
>          > The user should order it if needed;
>          >   The "leafs" of the tree can come in any order, and we should not try to order it there.
>          > Iulian
>          >     Hi iulian
>          >     Thanks for that, additional side question. When you specify the maximum number of intersection to return,
>         the list
>          >     is ordered in distance from the start point, when you specify 0, the list is unordered. Should we not expect
>          >     consistent behavior in both cases?
>          >     Thanks
>          >     Andy
>          >     Sent from my Samsung Galaxy Note™, an AT&T LTE smartphone
>          >     Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
>          >     it works fine if you do not specify the limit 100 for number of intersections.
>          >     If you leave it 0, it is fine;
>          >     (so call with kdtree->ray_intersect_triangles( kdtree_root, 1.0e-6,
>          >                              dir, box_center,
>          >                              intersection_facets
>          >                              , intersections);
>          >     I am still looking, but I think I am close :)
>          >         OK, obb tree works fine with the same model, default setting for everything
>          >         (you do no have to put tetras in the build, only the faces)
>          >         So there might be an issue with the kdtree.
>          >         I will look at it.
>          >         Iulian
>          >             The problem is on the secondrun, moving the starting point in the to y=4, then we get no
>         intersections
>          >             beyond 48.5.
>          >             On 07/24/2013 10:50 AM, Iulian Grindeanu wrote:
>          >                 I see no error
>          >                 Your fifth slab is at about 49.5;
>          >                 (first at 9.5, ..., fifth at 49.5)
>          >                 Iulian
>          >                     I think I may have found a bug in kdtree.
>          >                     My test problem consists of a tet mesh that is composed of some 4000
>          >                     tets. The mesh looks like that in mesh.png, a ray starts at position
>          >                     (1,0,0) and fires along (1,0,0) and we get the following results back
>          >                     from my test program swp.cpp
>          >                     Compile the minimum working example as
>          >                     g++ swp.cpp -I/<moab include dir> -L<moab lib dir> -lMOAB
>          >                     This is as expected,
>          >                     # of intersections : 20
>          >                     intersection distances are on 8.5 8.74072 9.25928 9.5 18.5 18.7407
>          >                     19.2593 19.5 28.5 28.7407 29.2593 29.5 38.5 38.7407 39.2593 39.5 48.5
>          >                     48.7407 49.2593 49.5 of ray length 900
>          >                     8.5 9.5 18.5 19.5 etc are the boundaries of the faces of the mesh.
>          >                     However, if we recompile and change the starting position to (1,4,0) we get
>          >                     # of intersections : 17
>          >                     intersection distances are on 8.5 8.63513 9.06064 9.5 18.5 18.6351
>          >                     19.0606 19.5 28.5 28.6351 29.0606 29.5 38.5 38.6351 39.0606 39.5 48.5 of
>          >                     ray length 900
>          >                     As far this ray is concerned there is no mesh in the 5th slab.
>          >                     What have I done wrong?
>          >                     Thanks
>          >                     Andy
>         "You will keep in perfect peace him whose mind is
>             steadfast, because he trusts in you."               Isaiah 26:3
>                        Tim Tautges            Argonne National Laboratory
>                    (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>            phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>                       fax: (608) 263-4499      Madison, WI 53706
