[MOAB-dev] Bug in kdtree?
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Thu Jul 25 17:14:24 CDT 2013
----- Original Message -----
| so the entities come out ordered according to the distance only if
| the max_ints is set.
| (only the first max_ints are returned, with the closest distance from
| the source of the ray)
| The bug is fixed now.
| So do you think that we should order them in all cases, for
| consistency?
then we should order them also for OBB tree. Do we have other trees with ray intersecting capability?
| That makes sense.
| Iulian
| | I do think the entries should be ordered at the end of the call,
| | after tree traversal is done, though.
| | - tim
| | On 07/24/2013 04:35 PM, Iulian Grindeanu wrote:
| | > the bug is around that logic, that I try to understand.
| | > It seems that the "ray_end" is reset, which is why some points
| | > are
| | > missed.
| | > I didn't write that logic, maybe Tim or Paul know who did.
| | > I don't think we should guarantee the order;
| | > The user should order it if needed;
| | > The "leafs" of the tree can come in any order, and we should not
| | > try to order it there.
| | > Iulian
| | > Hi iulian
| | > Thanks for that, additional side question. When you specify the
| | > maximum number of intersection to return, the list
| | > is ordered in distance from the start point, when you specify 0,
| | > the list is unordered. Should we not expect
| | > consistent behavior in both cases?
| | > Thanks
| | > Andy
| | > Sent from my Samsung Galaxy Note™, an AT&T LTE smartphone
| | > Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
| | > it works fine if you do not specify the limit 100 for number of
| | > intersections.
| | > If you leave it 0, it is fine;
| | > (so call with kdtree->ray_intersect_triangles( kdtree_root,
| | > 1.0e-6,
| | > dir, box_center,
| | > intersection_facets
| | > , intersections);
| | > I am still looking, but I think I am close :)
| | > OK, obb tree works fine with the same model, default setting for
| | > everything
| | > (you do no have to put tetras in the build, only the faces)
| | > So there might be an issue with the kdtree.
| | > I will look at it.
| | > Iulian
| | > The problem is on the secondrun, moving the starting point in the
| | > to y=4, then we get no intersections
| | > beyond 48.5.
| | > On 07/24/2013 10:50 AM, Iulian Grindeanu wrote:
| | > I see no error
| | > Your fifth slab is at about 49.5;
| | > (first at 9.5, ..., fifth at 49.5)
| | > Iulian
| | > I think I may have found a bug in kdtree.
| | > My test problem consists of a tet mesh that is composed of some
| | > 4000
| | > tets. The mesh looks like that in mesh.png, a ray starts at
| | > position
| | > (1,0,0) and fires along (1,0,0) and we get the following results
| | > back
| | > from my test program swp.cpp
| | > Compile the minimum working example as
| | > g++ swp.cpp -I/<moab include dir> -L<moab lib dir> -lMOAB
| | > This is as expected,
| | > # of intersections : 20
| | > intersection distances are on 8.5 8.74072 9.25928 9.5 18.5
| | > 18.7407
| | > 19.2593 19.5 28.5 28.7407 29.2593 29.5 38.5 38.7407 39.2593 39.5
| | > 48.5
| | > 48.7407 49.2593 49.5 of ray length 900
| | > 8.5 9.5 18.5 19.5 etc are the boundaries of the faces of the
| | > mesh.
| | > However, if we recompile and change the starting position to
| | > (1,4,0) we get
| | > # of intersections : 17
| | > intersection distances are on 8.5 8.63513 9.06064 9.5 18.5
| | > 18.6351
| | > 19.0606 19.5 28.5 28.6351 29.0606 29.5 38.5 38.6351 39.0606 39.5
| | > 48.5 of
| | > ray length 900
| | > As far this ray is concerned there is no mesh in the 5th slab.
| | > What have I done wrong?
| | > Thanks
| | > Andy
| | "You will keep in perfect peace him whose mind is
| | steadfast, because he trusts in you." Isaiah 26:3
| | Tim Tautges Argonne National Laboratory
| | (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
| | phone (gvoice): (608) 354-1459 1500 Engineering Dr.
| | fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130725/3f175648/attachment.html>
