[MOAB-dev] Bug in kdtree?
Andrew Davis
davisa at engr.wisc.edu
Wed Jul 24 09:32:00 CDT 2013
I think I may have found a bug in kdtree.
My test problem consists of a tet mesh that is composed of some 4000
tets. The mesh looks like that in mesh.png, a ray starts at position
(1,0,0) and fires along (1,0,0) and we get the following results back
from my test program swp.cpp
Compile the minimum working example as
g++ swp.cpp -I/<moab include dir> -L<moab lib dir> -lMOAB
This is as expected,
# of intersections : 20
intersection distances are on 8.5 8.74072 9.25928 9.5 18.5 18.7407
19.2593 19.5 28.5 28.7407 29.2593 29.5 38.5 38.7407 39.2593 39.5 48.5
48.7407 49.2593 49.5 of ray length 900
8.5 9.5 18.5 19.5 etc are the boundaries of the faces of the mesh.
However, if we recompile and change the starting position to (1,4,0) we get
# of intersections : 17
intersection distances are on 8.5 8.63513 9.06064 9.5 18.5 18.6351
19.0606 19.5 28.5 28.6351 29.0606 29.5 38.5 38.6351 39.0606 39.5 48.5 of
ray length 900
As far this ray is concerned there is no mesh in the 5th slab.
What have I done wrong?
Thanks
Andy
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130724/ef925667/attachment-0001.png>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130724/ef925667/attachment-0001.cpp>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130724/ef925667/attachment-0001.obj>
