[MOAB-dev] commit/MOAB: janehu: Minor change for styleguide for moab.
commits-noreply at bitbucket.org
Tue Jul 23 16:21:08 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/6be9d3c388a5/
Changeset: 6be9d3c388a5
Branch: master
User: janehu
Date: 2013-07-23 23:20:19
Summary: Minor change for styleguide for moab.
Affected #: 1 file
diff --git a/doc/DG/styleguide.h b/doc/DG/styleguide.h
index e3cf6f9..3a13e45 100644
--- a/doc/DG/styleguide.h
+++ b/doc/DG/styleguide.h
@@ -61,7 +61,7 @@ subdirectories in the %MOAB source code, except when implementing a new algorith
class using it.
- Any names introduced into the top-level MOAB namespace should be
sufficiently unique to avoid conflicts with other code. If you must
- introduce a class to the top-level Meshkit namespace, don't choose
+ introduce a class to the top-level MOAB namespace, don't choose
an overly genereric name like \c Point3D .
- Constants and Macros
- Don't use a pre-processor macro where a const variable or an inline or
@@ -69,7 +69,7 @@ subdirectories in the %MOAB source code, except when implementing a new algorith
There is absolutely benefit to the former over the later with modern
compilers. Further, using macros bypasses typechecking that the compiler
would otherwise do for you and if used in headers, introduce names into
- the global rather than Meshkit namespace.
+ the global rather than MOAB namespace.
- Don't define constants that are already provided by standard libraries.
For example, use \c M_PI as defined in \c math.h rather than defining
your own constant.
@@ -80,8 +80,8 @@ top-level directory. If you commit code that violates this principal, it should
code to a compilable state, and your second priority to make sure "make check" runs without errors.
Commits to the repository should also come with a non-trivial, useful, non-verbose log message. Oftentimes the best way to generate
-this message is to run 'svn diff > diffs', and edit the diffs file to remove specific line changes but include a comment on
-each file that changed. Many times it is helpful to state that 'make check runs successfully' at the end of the log message.
+this message is to run 'commit -a', and include a comment on
+each file that changed, then Ctrl+O to write out, followed by 'Enter' and Ctrl+X. Many times it is helpful to state that 'make check runs successfully' at the end of the log message.
Although it would be possible and many software projects do it, we prefer not to force successful execution of the test suite
before every commit. Developers should make every effort to avoid having to impose this constraint, by running a make check
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
