[MOAB-dev] commit/MOAB: danwu: Replace tab with spaces for indentation in NCHelperHOMME.cpp, line 37
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Wed Jun 5 15:46:20 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/80b469fb1569/
Changeset:   80b469fb1569
Branch:      master
User:        danwu
Date:        2013-06-05 22:46:02
Summary:     Replace tab with spaces for indentation in NCHelperHOMME.cpp, line 37
Affected #:  1 file
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index 6490b24..32faa58 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -34,7 +34,7 @@ bool NCHelperHOMME::can_read_file(ReadNC* readNC, int fileId)
   // If global attribute "np" exists then it should be the HOMME grid
   if (readNC->globalAtts.find("np") != readNC->globalAtts.end()) {
     // Make sure it is CAM grid
-	std::map<std::string, ReadNC::AttData>::iterator attIt = readNC->globalAtts.find("source");
+    std::map<std::string, ReadNC::AttData>::iterator attIt = readNC->globalAtts.find("source");
     if (attIt == readNC->globalAtts.end()) {
       readNC->readMeshIface->report_error("%s", "File does not have source global attribute.");
       return false;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
