[MOAB-dev] commit/MOAB: danwu: Update test/io/read_nc.cpp to add test cases for reading MeshFiles/unittest/io/fv26x46x72.t.3.nc
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Wed Jun 5 15:12:22 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/eafc99afd458/
Changeset:   eafc99afd458
Branch:      master
User:        danwu
Date:        2013-06-05 22:11:35
Summary:     Update test/io/read_nc.cpp to add test cases for reading MeshFiles/unittest/io/fv26x46x72.t.3.nc
Affected #:  1 file
diff --git a/test/io/read_nc.cpp b/test/io/read_nc.cpp
index 0e5af72..558958c 100644
--- a/test/io/read_nc.cpp
+++ b/test/io/read_nc.cpp
@@ -4,74 +4,240 @@
 using namespace moab;
 #ifdef MESHDIR
-static const char example[] = STRINGIFY(MESHDIR) "/io/camEul26x48x96.t3.nc";
+static const char example_eul[] = STRINGIFY(MESHDIR) "/io/camEul26x48x96.t3.nc";
+static const char example_fv[] = STRINGIFY(MESHDIR) "/io/fv26x46x72.t.3.nc";
 #else
-static const char example[] = "/io/camEul26x48x96.t3.nc";
+static const char example_eul[] = "/io/camEul26x48x96.t3.nc";
+static const char example_fv[] = "/io/fv26x46x72.t.3.nc";
 #endif
 #ifdef USE_MPI
 #include "moab_mpi.h"
 #endif
-void read_file( Interface& moab, const char* input_file );
-void test_read_all();
-void test_read_onevar();
-void test_read_onetimestep();
-void test_read_nomesh();
-void test_read_novars();
-ErrorCode get_options(std::string &opts);
+// CAM-EUL
+void test_read_eul_all();
+void test_read_eul_onevar();
+void test_read_eul_onetimestep();
+void test_read_eul_nomesh();
+void test_read_eul_novars();
-int main(int argc, char *argv[])
+// CAM-FV
+void test_read_fv_all();
+void test_read_fv_onevar();
+void test_read_fv_onetimestep();
+void test_read_fv_nomesh();
+void test_read_fv_novars();
+ErrorCode get_options(std::string& opts);
+int main(int argc, char* argv[])
   int result = 0;
 #ifdef USE_MPI
   int fail = MPI_Init(&argc, &argv);
-  if (fail) return 1;
+  if (fail)
+    return 1;
 #else
-  argv[0]=argv[argc-argc];// to remove the warnings in serial mode about unused variables
+  argv[0] = argv[argc - argc]; // to remove the warnings in serial mode about unused variables
 #endif
-  result += RUN_TEST(test_read_all);
-  result += RUN_TEST(test_read_onevar);
-  result += RUN_TEST(test_read_onetimestep);
-  result += RUN_TEST(test_read_nomesh);
-  result += RUN_TEST(test_read_novars);
+  result += RUN_TEST(test_read_eul_all);
+  result += RUN_TEST(test_read_eul_onevar);
+  result += RUN_TEST(test_read_eul_onetimestep);
+  result += RUN_TEST(test_read_eul_nomesh);
+  result += RUN_TEST(test_read_eul_novars);
+  // Exclude test_read_fv_all() since reading edge data is not implemented in MOAB yet
+  //result += RUN_TEST(test_read_fv_all);
+  result += RUN_TEST(test_read_fv_onevar);
+  result += RUN_TEST(test_read_fv_onetimestep);
+  result += RUN_TEST(test_read_fv_nomesh);
+  result += RUN_TEST(test_read_fv_novars);
 #ifdef USE_MPI
   fail = MPI_Finalize();
   if (fail) return 1;
 #endif
   return result;
+  Core moab;
+  Interface& mb = moab;
+  std::string opts;
+  ErrorCode rval = get_options(opts);
+  CHECK_ERR(rval);
+  rval = mb.load_file(example_eul, NULL, opts.c_str());
+  CHECK_ERR(rval);
+    // check for proper tags
+  Tag Ttag0, Ttag1, coordTag;
+  rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0);
+  CHECK_ERR(rval);
+  rval = mb.tag_get_handle("T1", 26, MB_TYPE_DOUBLE, Ttag1);
+  CHECK_ERR(rval);
+  rval = mb.tag_get_handle("COORDS", 3, MB_TYPE_DOUBLE, coordTag);
+  CHECK_ERR(rval);
   Core moab;
+  std::string opts;
+  CHECK_ERR(rval);
+  opts += std::string(";VARIABLE=T");
+  CHECK_ERR(rval);
+  Tag Ttag0, Ttag1;
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
+  Core moab;
   std::string opts;
   CHECK_ERR(rval);
-  rval = mb.load_file( example, NULL, opts.c_str());
+  opts += std::string(";VARIABLE=T;TIMESTEP=1");
   CHECK_ERR(rval);
+  Tag Ttag0, Ttag1;
+  CHECK_EQUAL(rval, MB_TAG_NOT_FOUND);
+  CHECK_ERR(rval);
+  Core moab;
+    // need a set for nomesh to work right
+  EntityHandle set;
+  ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
+  CHECK_ERR(rval);
+  std::string orig, opts;
+  rval = get_options(orig);
+  CHECK_ERR(rval);
+  opts = orig + std::string(";VARIABLE=T;TIMESTEP=0");
+  rval = mb.load_file(example_eul, &set, opts.c_str());
+  CHECK_ERR(rval);
+  Tag Ttag0, Ttag1;
+  CHECK_ERR(rval);
+    // now read 2nd timestep with nomesh option
+  opts = orig + std::string(";VARIABLE=T;TIMESTEP=1;NOMESH");
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
+  Core moab;
+  EntityHandle set;
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
+  opts = orig + std::string(";NOMESH;VARIABLE=");
+  CHECK_ERR(rval);
+  opts = orig + std::string(";VARIABLE=;TIMESTEP=0");
+  CHECK_ERR(rval);
+  Tag Ttag0, Ttag1;
+  opts = orig + std::string(";VARIABLE=T;TIMESTEP=0;NOMESH");
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
+  Core moab;
+  std::string opts;
+  CHECK_ERR(rval);
+  rval = mb.load_file(example_fv, NULL, opts.c_str());
+  CHECK_ERR(rval);
   CHECK_ERR(rval);
   CHECK_ERR(rval);
-  rval=mb.tag_get_handle("COORDS", 3 ,MB_TYPE_DOUBLE, coordTag);
+  rval=mb.tag_get_handle("COORDS", 3, MB_TYPE_DOUBLE, coordTag);
   CHECK_ERR(rval);
   Core moab;
@@ -80,19 +246,19 @@ void test_read_onevar()
   CHECK_ERR(rval);
   CHECK_ERR(rval);
   Tag Ttag0, Ttag1;
   CHECK_ERR(rval);
   CHECK_ERR(rval);
   Core moab;
@@ -100,20 +266,20 @@ void test_read_onetimestep()
   CHECK_ERR(rval);
-  opts += std::string(";TIMESTEP=1");
-  rval = mb.load_file( example, NULL, opts.c_str() );
   CHECK_ERR(rval);
   Tag Ttag0, Ttag1;
   CHECK_ERR(rval);
   Core moab;
@@ -122,34 +288,34 @@ void test_read_nomesh()
   EntityHandle set;
   CHECK_ERR(rval);
   CHECK_ERR(rval);
-  opts = orig + std::string(";TIMESTEP=0");
-  rval = mb.load_file( example, &set, opts.c_str() );
+  rval = mb.load_file(example_fv, &set, opts.c_str());
   CHECK_ERR(rval);
   Tag Ttag0, Ttag1;
   CHECK_ERR(rval);
-  opts = orig + std::string(";TIMESTEP=1;NOMESH");
   CHECK_ERR(rval);
   CHECK_ERR(rval);
   Core moab;
@@ -158,28 +324,28 @@ void test_read_novars()
   EntityHandle set;
   CHECK_ERR(rval);
   CHECK_ERR(rval);
   CHECK_ERR(rval);
   CHECK_ERR(rval);
   Tag Ttag0, Ttag1;
   CHECK_ERR(rval);
   CHECK_ERR(rval);
@@ -187,16 +353,16 @@ void test_read_novars()
   CHECK_ERR(rval);
   CHECK_ERR(rval);
 #ifdef USE_MPI
     // use parallel options
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
