[MOAB-dev] commit/MOAB: tautges: Backing out changes from 732016a that changed how fortran apps were linked.
    Tim Tautges
    tautges at mcs.anl.gov
    Thu May 23 11:12:18 CDT 2013
Should have been fixed long ago.
- tim
On 05/23/2013 08:35 AM, Iulian Grindeanu wrote:
> So it seems that this fix solved the moab-intel build!
> Thanks!
> http://gnep.mcs.anl.gov:8010/builders/moab-intel
> Iulian
>     1 new commit in MOAB:
>     https://bitbucket.org/fathomteam/moab/commits/6a19421bba55/
>     Changeset:   6a19421bba55
>     Branch:      master
>     User:        tautges
>     Date:        2013-05-22 21:06:09
>     Summary:     Backing out changes from 732016a that changed how fortran apps were linked.
>     Too many machine dependencies in this approach, and ended up not fixing
>     probs on IBM BG.
>     Affected #:  3 files
>     diff --git a/config/compiler.m4 b/config/compiler.m4
>     index e869c33..81596a6 100644
>     --- a/config/compiler.m4
>     +++ b/config/compiler.m4
>     @@ -126,8 +126,6 @@ fi
>       if test "xno" != "x$CHECK_FC"; then
>         AC_PROG_FC
>         AC_PROG_F77
>     -  AC_F77_LIBRARY_LDFLAGS
>     -  AC_FC_LIBRARY_LDFLAGS
>       fi
>       ]) # FATHOM_CHECK_COMPILERS
>     diff --git a/configure.ac b/configure.ac
>     index 1524b06..c9d6387 100644
>     --- a/configure.ac
>     +++ b/configure.ac
>     @@ -67,14 +67,6 @@ if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FC"; then
>         AC_FC_WRAPPERS
>       fi
>     -if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FLIBS"; then
>     -   LIBS="$LIBS $FLIBS"
>     -fi
>     -if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FCLIBS"; then
>     -   LIBS="$LIBS $FCLIBS"
>     -fi
>       #                           Check for need for extra flags to support cray pointers
>     @@ -1230,10 +1222,10 @@ AC_OUTPUT
>       AC_MSG_RESULT([C:   $CC $CFLAGS $CPPFLAGS])
>       AC_MSG_RESULT([C++: $CXX $CXXFLAGS $CPPFLAGS])
>       if test "x" != "x$FC"; then
>     -  AC_MSG_RESULT([Fortran: $FC $FCFLAGS])
>     +  AC_MSG_RESULT([Fortran90: $FC $FCFLAGS])
>       fi
>       if test "x" != "x$F77"; then
>     -  AC_MSG_RESULT([Fortran: $F77 $FFLAGS])
>     +  AC_MSG_RESULT([Fortran77: $F77 $FFLAGS])
>       fi
>       if test "x$HAVE_HDF5" = "xno"; then
>     diff --git a/itaps/imesh/Makefile.am b/itaps/imesh/Makefile.am
>     index 97c76bb..647b8c1 100644
>     --- a/itaps/imesh/Makefile.am
>     +++ b/itaps/imesh/Makefile.am
>     @@ -45,9 +45,6 @@ if PARALLEL
>       #  ftest_DEPENDENCIES = libiMesh.la $(top_builddir)/libMOAB.la
>       endif
>     -FCLINK = $(CXXLINK)
>     -F77LINK = $(CXXLINK)
>       TESTS = $(check_PROGRAMS)
>       LDADD = libiMesh.la $(top_builddir)/src/libMOAB.la ${MOAB_CXX_LINKFLAGS} ${MOAB_CXX_LIBS}
>       TESTDEPS = libiMesh.la $(top_builddir)/src/libMOAB.la
>     Repository URL: https://bitbucket.org/fathomteam/moab/
>     This is a commit notification from bitbucket.org. You are receiving
>     this because you have the service enabled, addressing the recipient of
>     this email.
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
