[MOAB-dev] commit/MOAB: tautges: Backing out changes from 732016a that changed how fortran apps were linked.
Iulian Grindeanu iulian at mcs.anl.gov
Thu May 23 08:35:36 CDT 2013
So it seems that this fix solved the moab-intel build!
Thanks!
http://gnep.mcs.anl.gov:8010/builders/moab-intel
Iulian
----- Original Message -----
| 1 new commit in MOAB:
| https://bitbucket.org/fathomteam/moab/commits/6a19421bba55/
| Changeset: 6a19421bba55
| Branch: master
| User: tautges
| Date: 2013-05-22 21:06:09
| Summary: Backing out changes from 732016a that changed how fortran
| apps were linked.
| Too many machine dependencies in this approach, and ended up not
| fixing
| probs on IBM BG.
| Affected #: 3 files
| diff --git a/config/compiler.m4 b/config/compiler.m4
| index e869c33..81596a6 100644
| --- a/config/compiler.m4
| +++ b/config/compiler.m4
| @@ -126,8 +126,6 @@ fi
| if test "xno" != "x$CHECK_FC"; then
| AC_PROG_FC
| AC_PROG_F77
| - AC_F77_LIBRARY_LDFLAGS
| - AC_FC_LIBRARY_LDFLAGS
| fi
| ]) # FATHOM_CHECK_COMPILERS
| diff --git a/configure.ac b/configure.ac
| index 1524b06..c9d6387 100644
| --- a/configure.ac
| +++ b/configure.ac
| @@ -67,14 +67,6 @@ if test "xyes" = "x$ENABLE_FORTRAN" && test "x" !=
| "x$FC"; then
| AC_FC_WRAPPERS
| fi
| -if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FLIBS"; then
| - LIBS="$LIBS $FLIBS"
| -fi
| -if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FCLIBS"; then
| - LIBS="$LIBS $FCLIBS"
| -fi
| # Check for need for extra flags to support cray pointers
| @@ -1230,10 +1222,10 @@ AC_OUTPUT
| AC_MSG_RESULT([C: $CC $CFLAGS $CPPFLAGS])
| AC_MSG_RESULT([C++: $CXX $CXXFLAGS $CPPFLAGS])
| if test "x" != "x$FC"; then
| - AC_MSG_RESULT([Fortran: $FC $FCFLAGS])
| + AC_MSG_RESULT([Fortran90: $FC $FCFLAGS])
| fi
| if test "x" != "x$F77"; then
| - AC_MSG_RESULT([Fortran: $F77 $FFLAGS])
| + AC_MSG_RESULT([Fortran77: $F77 $FFLAGS])
| fi
| if test "x$HAVE_HDF5" = "xno"; then
| diff --git a/itaps/imesh/Makefile.am b/itaps/imesh/Makefile.am
| index 97c76bb..647b8c1 100644
| --- a/itaps/imesh/Makefile.am
| +++ b/itaps/imesh/Makefile.am
| @@ -45,9 +45,6 @@ if PARALLEL
| # ftest_DEPENDENCIES = libiMesh.la $(top_builddir)/libMOAB.la
| endif
| -FCLINK = $(CXXLINK)
| -F77LINK = $(CXXLINK)
| TESTS = $(check_PROGRAMS)
| LDADD = libiMesh.la $(top_builddir)/src/libMOAB.la
| ${MOAB_CXX_LINKFLAGS} ${MOAB_CXX_LIBS}
| TESTDEPS = libiMesh.la $(top_builddir)/src/libMOAB.la
| Repository URL: https://bitbucket.org/fathomteam/moab/
| This is a commit notification from bitbucket.org. You are receiving
| this because you have the service enabled, addressing the recipient
| of
| this email.
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130523/119ce00d/attachment.html>
