[MOAB-dev] commit/MOAB: 2 new changesets
    commits-noreply at bitbucket.org
    Thu Apr 18 16:25:25 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/143d15e50b79/
Changeset:   143d15e50b79
Branch:      None
User:        iulian07
Date:        2013-04-18 23:09:43
Summary:     typo in get adjacency for polygons
pointed out by Andrew Cunningham
it was not caught by any test;
method needs work anyway for the case "create_if_missing=true"
Affected #:  1 file
diff --git a/src/AEntityFactory.cpp b/src/AEntityFactory.cpp
index cbc56dd..3d04244 100644
--- a/src/AEntityFactory.cpp
+++ b/src/AEntityFactory.cpp
@@ -795,7 +795,7 @@ ErrorCode AEntityFactory::get_down_adjacency_elements_poly(EntityHandle source_e
   EntityType source_type = TYPE_FROM_HANDLE(source_entity);
   if (!(source_type == MBPOLYHEDRON && target_dimension > 0 && target_dimension < 3) &&
-      (!source_type == MBPOLYGON && target_dimension == 1))
+      !(source_type == MBPOLYGON && target_dimension == 1))
     return MB_TYPE_OUT_OF_RANGE;
     // make this a fixed size to avoid cost of working with STL vectors
https://bitbucket.org/fathomteam/moab/commits/fd126f07f119/
Changeset:   fd126f07f119
Branch:      master
User:        iulian07
Date:        2013-04-18 23:20:42
Summary:     Merge branch 'master' of bitbucket.org:iulian07/moab
Affected #:  5 files
diff --git a/examples/StructuredMeshSimple.cpp b/examples/StructuredMeshSimple.cpp
new file mode 100644
index 0000000..25aa08f
--- /dev/null
+++ b/examples/StructuredMeshSimple.cpp
@@ -0,0 +1,110 @@
+/** @example StructuredMeshSimple.cpp
+ * \brief Show creation and query of structured mesh, serial or parallel, through MOAB's structured mesh interface.
+ * This is an example showing creation and query of a 3D structured mesh.  In serial, a single N*N*N block of elements
+ * is created; in parallel, each proc gets an N*N*N block, with blocks arranged in a 1d column, sharing vertices
+ * and faces at their interfaces (proc 0 has no left neighbor and proc P-1 no right neighbor).
+ * Each square block of hex elements is then referenced by its ijk parameterization.
+ * 1D and 2D examples could be made simply by changing the dimension parameter passed into the MOAB functions. \n
+ * <b>This example </b>:
+ *    -# Instantiate MOAB and get the structured mesh interface
+ *    -# Decide what the local parameters of the mesh will be, based on parallel/serial and rank.
+ *    -# Create a N^d structured mesh, which includes (N+1)^d vertices and N^d elements.
+ *    -# Get the vertices and elements from moab and check their numbers against (N+1)^d and N^d, resp.
+ *    -# Loop over elements in d nested loops over i, j, k; for each (i,j,k):
+ *      -# Get the element corresponding to (i,j,k)
+ *      -# Get the connectivity of the element
+ *      -# Get the coordinates of the vertices comprising that element
+ *    -# Release the structured mesh interface and destroy the MOAB instance
+ * <b> To run: </b> ./structuredmesh [d [N] ] \n
+ * (default values so can run w/ no user interaction)
+#include "moab/Core.hpp"
+#include "moab/ScdInterface.hpp"
+#include "moab/ProgOptions.hpp"
+#include "moab/CN.hpp"
+#include <iostream>
+#include <vector>
+using namespace moab;
+int main(int argc, char **argv)
+  int N = 10, dim = 3;
+  ProgOptions opts;
+  opts.addOpt<int>(std::string("dim,d"), std::string("Dimension of mesh (default=3)"),
+                   &dim);
+  opts.addOpt<int>(std::string(",n"), std::string("Number of elements on a side (default=10)"),
+                   &N);
+  opts.parseCommandLine(argc, argv);
+    // 0. Instantiate MOAB and get the structured mesh interface
+  Interface *mb = new Core();
+  ScdInterface *scdiface;
+  ErrorCode rval = mb->query_interface(scdiface); // get a ScdInterface object through moab instance
+  if (MB_SUCCESS != rval) return rval;
+    // 1. Decide what the local parameters of the mesh will be, based on parallel/serial and rank.
+  int ilow = 0, ihigh = N;
+  int rank = 0, nprocs = 1;
+#ifdef USE_MPI
+  MPI_Comm_size(MPI_COMM_WORLD, &nprocs); MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  ilow = rank*N; ihigh = ilow + N;
+#endif
+    // 2. Create a N^d structured mesh, which includes (N+1)^d vertices and N^d elements.
+  ScdBox *box;
+  rval = scdiface->construct_box(HomCoord(ilow, (dim>1?0:-1), (dim>2?0:-1)), // use in-line logical tests to handle dimensionality
+                                 HomCoord(ihigh, (dim>1?N:-1), (dim>2?N:-1)),
+                                 NULL, 0, // NULL coords vector and 0 coords (don't specify coords for now)
+                                 box);    // box is the structured box object providing the parametric
+                                          // structured mesh interface for this rectangle of elements
+    // 3. Get the vertices and elements from moab and check their numbers against (N+1)^d and N^d, resp.
+  Range verts, elems;
+  rval = mb->get_entities_by_dimension(0, 0, verts); // first '0' specifies "root set", or entire MOAB instance, second the entity dimension being requested
+  rval = mb->get_entities_by_dimension(0, dim, elems);
+#define MYSTREAM(a) if (!rank) std::cout << a << std::endl
+  if (pow(N,dim) == (int) elems.size() && pow(N+1,dim) == (int) verts.size()) { // expected #e and #v are N^d and (N+1)^d, resp.
+#ifdef USE_MPI
+    MYSTREAM("Proc 0: ");
+#endif
+    MYSTREAM("Created " << elems.size() << " " << CN::EntityTypeName(mb->type_from_handle(*elems.begin()))
+             << " elements and " << verts.size() << " vertices." << std::endl);
+  else
+    std::cout << "Created the wrong number of vertices or hexes!" << std::endl;
+    // 4. Loop over elements in 3 nested loops over i, j, k; for each (i,j,k):
+  std::vector<double> coords(3*pow(N+1,dim));
+  std::vector<EntityHandle> connect;
+  for (int k = 0; k < (dim>2?N:1); k++) {
+    for (int j = 0; j < (dim>1?N:1); j++) {
+      for (int i = 0; i < N-1; i++) {
+          // 4a. Get the element corresponding to (i,j,k)
+        EntityHandle ehandle = box->get_element(i, j, k);
+        if (0 == ehandle) return MB_FAILURE;
+          // 4b. Get the connectivity of the element
+        rval = mb->get_connectivity(&ehandle, 1, connect); // get the connectivity, in canonical order
+          // 4c. Get the coordinates of the vertices comprising that element
+        rval = mb->get_coords(connect.data(), connect.size(), coords.data()); // get the coordinates of those vertices
+    // 5. Release the structured mesh interface and destroy the MOAB instance
+  mb->release_interface(scdiface); // tell MOAB we're done with the ScdInterface
+  delete mb;
+  return 0;
diff --git a/examples/makefile b/examples/makefile
index dcf7029..4ec6154 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -20,7 +20,7 @@ HelloMoabPar: HelloMoabPar.o
 TestExodusII: TestExodusII.o
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
 .cpp.o :
 	${MOAB_CXX} ${MOAB_CXXFLAGS} ${MOAB_INCLUDES} -DMESH_DIR=\"${MESH_DIR}\" -c $<
diff --git a/itaps/iBase.h b/itaps/iBase.h
index 5172bb8..933b9d6 100644
--- a/itaps/iBase.h
+++ b/itaps/iBase.h
@@ -261,7 +261,7 @@ enum iBase_TagValueType {
- * \mainpage The ITAPS Interfaces
+ * \page The ITAPS Interfaces
  * \subpage ibase
@@ -281,6 +281,8 @@ enum iBase_TagValueType {
  * \subpage numhops
+ * \subpage resilient
  * \page error Error Handling
  * With few exceptions, every iMesh function includes an output argument,
diff --git a/itaps/imesh/iMeshP.h b/itaps/imesh/iMeshP.h
index 958c827..28da490 100644
--- a/itaps/imesh/iMeshP.h
+++ b/itaps/imesh/iMeshP.h
@@ -33,7 +33,7 @@ enum iMeshP_EntStatus
 #define iMeshP_ALL_PARTS -1
-/** \mainpage
+/** \page imeshp  iMeshP: ITAPS Parallel Mesh Interface
 iMeshP.h -- ITAPS Parallel Mesh Interface
 Release 0.1; October 2008
@@ -45,7 +45,7 @@ Release 0.1; October 2008
    subsets; like a "mesh," it does not imply a serial or parallel
    implementation.
 -  An application may use one or more meshes.
--  Parititions can create subsets of entities from one or more meshes.
+-  Partitions can create subsets of entities from one or more meshes.
 -  Meshes can be subdivided by one or more partitions.
 -  Partitions contain parts.  Parts contain the subsets of entities in the
    partition.
diff --git a/src/io/mhdf/include/mhdf.h b/src/io/mhdf/include/mhdf.h
index e8aaa90..9a7a478 100644
--- a/src/io/mhdf/include/mhdf.h
+++ b/src/io/mhdf/include/mhdf.h
@@ -22,7 +22,7 @@
 extern "C" {
 #endif
-/** \mainpage H5M File Format API
+/** \page h5mmain H5M File Format API
  *\section Intro   Introduction
@@ -60,7 +60,7 @@ extern "C" {
  * hexahedral topology) and the number of nodes in the element.
- *\section Root   The \c tstt Group
+ *\section Root   The tstt Group
  * All file data is stored in the \c tstt group in the HDF5 root group.
  * The \c tstt group may have an optional scalar integer attribute
@@ -87,12 +87,12 @@ extern "C" {
  * - \c Polyhedron
- *\section History   The \c history DataSet
+ *\section History   The history DataSet
  * The \c history DataSet is a list of variable-length strings with
- * appliation-defined meaning.
+ * application-defined meaning.
- *\section Nodes   The \c nodes Group
+ *\section Nodes   The nodes Group
  * The \c nodes group contains a single DataSet and an optional
@@ -111,7 +111,7 @@ extern "C" {
  * \c coordinates table.
- *\section Elements   The \c elements Group
+ *\section Elements   The elements Group
  * The \c elements group contains an application-defined number of
  * subgroups.  Each subgroup defines one or more mesh elements that
@@ -141,7 +141,7 @@ extern "C" {
  * sequentially in the order that they are defined in the table.
- *\section Sets   The \c sets Group
+ *\section Sets   The sets Group
  * The \c sets group contains the definitions of any entity sets stored
  * in the file.  It contains 1 to 4 DataSets and the optional \c tags
@@ -199,7 +199,7 @@ extern "C" {
  * subgroup is described in the \ref Dense "section on dense tag storage".
- * \section Tags   The \c tags Group
+ * \section Tags   The tags Group
  * The \c tags group contains a sub-group for each tag defined
  * in the file.  These sub-groups contain the definition of the
@@ -283,7 +283,7 @@ extern "C" {
  * dataset.
- * \section Dense   The \c tags Sub-Groups
+ * \section Dense   The tags Sub-Groups
  * Data for fixed-length tags may also be stored in the \c tags sub-group
  * of the \c nodes, \c sets, and subgroups of the \c elements group.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
