[MOAB-dev] commit/MOAB: 10 new changesets
Bitbucket
commits-noreply at bitbucket.org
Mon Apr 1 15:50:20 CDT 2013
10 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/5104e1f01267/
Changeset: 5104e1f01267
Branch: None
User: vijaysm
Date: 2013-03-20 00:19:44
Summary: Remove multiple warnings due to -Wshadow in TupleList implementation.
Affected #: 2 files
https://bitbucket.org/fathomteam/moab/commits/a68410defb58/
Changeset: a68410defb58
Branch: None
User: vijaysm
Date: 2013-03-20 00:20:14
Summary: Add linear edge basis functions to handle 1-d elements in the coupler. Still needs further testing.
Affected #: 2 files
https://bitbucket.org/fathomteam/moab/commits/65c487a61446/
Changeset: 65c487a61446
Branch: None
User: vijaysm
Date: 2013-03-20 00:20:20
Summary: Adding a global ignore file to eliminate all configure time generated files that dont need to be in the repository tracked list.
Affected #: 1 file
https://bitbucket.org/fathomteam/moab/commits/9d6e9d8e865a/
Changeset: 9d6e9d8e865a
Branch: None
User: vijaysm
Date: 2013-03-20 00:20:26
Summary: Remove the redundant static implementation in the header and replace with just function declarations.
Affected #: 1 file
https://bitbucket.org/fathomteam/moab/commits/ce299506f144/
Changeset: ce299506f144
Branch: None
User: vijaysm
Date: 2013-03-20 00:20:31
Summary: Adding a error check when a specific format writer fails. The error needs to be propagated and needs context.
Affected #: 1 file
https://bitbucket.org/fathomteam/moab/commits/378599dba48e/
Changeset: 378599dba48e
Branch: None
User: vijaysm
Date: 2013-03-20 00:20:38
Summary: Add descriptive documentation options to have a TOC, enable search, browse sources in file and with inline sources below declarations.
Affected #: 1 file
https://bitbucket.org/fathomteam/moab/commits/cd834aa4b14e/
Changeset: cd834aa4b14e
Branch: None
User: vijaysm
Date: 2013-03-20 00:20:43
Summary: Adding ignore files for compiled test and tools programs.
Affected #: 9 files
https://bitbucket.org/fathomteam/moab/commits/3400f0902f20/
Changeset: 3400f0902f20
Branch: None
User: vijaysm
Date: 2013-03-20 00:21:06
Summary: Ignoring the configured moab file and .libs globally in the repo.
Affected #: 1 file
https://bitbucket.org/fathomteam/moab/commits/14c1d6d133db/
Changeset: 14c1d6d133db
Branch: None
User: vijaysm
Date: 2013-03-20 00:21:13
Summary: Use the correct include for ElemUtil. Need to remove the one in src/
Affected #: 1 file
https://bitbucket.org/fathomteam/moab/commits/89ab981c5b57/
Changeset: 89ab981c5b57
Branch: master
User: vijaysm
Date: 2013-04-01 22:49:29
Summary: Merge remote-tracking branch 'upstream/master'
Affected #: 4 files
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
