[MOAB-dev] r6024 - MOAB/trunk/tools/mbcslam
iulian at mcs.anl.gov
Wed Mar 6 12:58:38 CST 2013
Author: iulian
Date: 2013-03-06 12:58:38 -0600 (Wed, 06 Mar 2013)
New Revision: 6024
Added:
MOAB/trunk/tools/mbcslam/case1_test.cpp
Modified:
MOAB/trunk/tools/mbcslam/CslamUtils.cpp
MOAB/trunk/tools/mbcslam/CslamUtils.hpp
MOAB/trunk/tools/mbcslam/Makefile.am
Log:
first test case for robustness
"A Class of Deformational Flow Test Cases for Linear Transport Problems on the Sphere" JCP 2010.
delta t can be passed with option -dt, while geometric tolerance with -gtol
the radius of the sphere in paper is 1, here it can be specified with -cube
-cube will define the side of the cube , from here the radius is CubeSide / 2 * sqrt(3.)
Modified: MOAB/trunk/tools/mbcslam/CslamUtils.cpp
--- MOAB/trunk/tools/mbcslam/CslamUtils.cpp 2013-03-05 19:40:36 UTC (rev 6023)
+++ MOAB/trunk/tools/mbcslam/CslamUtils.cpp 2013-03-06 18:58:38 UTC (rev 6024)
@@ -788,4 +788,59 @@
return total_area;
+double distance_on_great_circle(CartVect & p1, CartVect & p2)
+ SphereCoords sph1 = cart_to_spherical(p1);
+ SphereCoords sph2 = cart_to_spherical(p2);
+ // radius should be the same
+ return sph1.R * acos(sin (sph1.lon)* sin(sph2.lon) + cos(sph1.lat)*cos(sph2.lat)*cos(sph2.lon-sph2.lon) );
+ * based on paper A class of deformational flow test cases for linear transport problems on the sphere
+ * longitude lambda [0.. 2*pi) and latitude theta (-pi/2, pi/2)
+ * lambda: -> lon (0, 2*pi)
+ * theta : -> lat (-pi/2, po/2)
+ * Radius of the sphere is 1 (if not, everything gets multiplied by 1)
+ * cosine bell: center lambda0, theta0:
+void departure_point_case1(CartVect & arrival_point, double t, double delta_t, CartVect & departure_point)
+ // always assume radius is 1 here?
+ SphereCoords sph = cart_to_spherical(arrival_point);
+ double T=5; // duration of integration (5 units)
+ double k = 2.4; //flow parameter
+ /* radius needs to be within some range */
+ double sl2 = sin(sph.lon/2);
+ double pit = M_PI * t / T;
+ double omega = M_PI/T;
+ double costetha = cos(sph.lat);
+ //double u = k * sl2*sl2 * sin(2*sph.lat) * cos(pit);
+ double v = k * sin(sph.lon) * costetha * cos(pit);
+ //double psi = k * sl2 * sl2 *costetha * costetha * cos(pit);
+ double u_tilda = 2*k*sl2*sl2*sin(sph.lat)*cos(pit);
+ // formula 35, page 8
+ // this will approximate dep point using a Taylor series with up to second derivative
+ // this will be O(delta_t^3) exact.
+ double lon_dep = sph.lon - delta_t * u_tilda -delta_t*delta_t * k * sl2 *
+ ( sl2 * sin (sph.lat) * sin(pit) * omega
+ - u_tilda * sin(sph.lat) * cos(pit) * cos (sph.lon/2)
+ - v * sl2 * costetha * cos(pit) );
+ // formula 36, page 8 again
