[MOAB-dev] Tonight for switchover to git / bitbucket?
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Tue Mar  5 19:06:32 CST 2013
Well I have some minor local changes that fix warnings etc which arent
a priority. I could do a diff and then patch the new working copy. I
also have some extensive changes to the Coupler to enable
normalization correctly and the modifications completely remove all
usages of iMeshInstance which has been the cause of breakage
(segfaults) in all normalization routines. I forked the bitbucket repo
already and will test the new code there and submit pull request once
I am done.
Anyway, I am fine with moving now but I was talking in general to
allow time for other developers to transition smoothly. If there are
no other objections, go ahead with making the new repo as the official
location.
Vijay
On Tue, Mar 5, 2013 at 6:50 PM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> Ok, I'll wait.  But, let's say we'll move the repo sometime Friday
> afternoon.  I'll turn off writing before doing it, though, and at worst you
> can do local svn status checks to see what you've changed and can re-apply
> those diffs on top of a git clone'd copy.
> - tim
> On 03/05/2013 04:18 PM, Vijay S. Mahadevan wrote:
>> Tim,
>> It is important to have at least couple of days to update all local
>> working copies before we start pushing proper into the bitbucket
>> repository since any existing unpushed changes will be messy to merge
>> otherwise. And the buildbot transition can happen alongside too in the
>> coming week.
>> A week from now, we can perform a final merge of any leftover commits
>> in the existing svn repo that is not synced to bitbucket. I think a
>> one week window is necessary before the transition happens completely.
>> Vijay
>> On Tue, Mar 5, 2013 at 4:04 PM, Iulian Grindeanu <iulian at mcs.anl.gov>
>> wrote:
>>> Will the svn repo still be on?
>>> Should I adjust the buildbot?
>>> Iulian
>>> ________________________________
>>> Hi all,
>>>     How does everyone feel about tonight being the switchover to
>>> git/bitbucket for the MOAB repo?
>>> Note, CGM, Lasso, and MeshKit will not switch with it, but will be
>>> delayed a
>>> week or two (to let the dust settle for
>>> MOAB and make sure we don't have all the tools down at once).
>>> - tim
>>> "You will keep in perfect peace him whose mind is
>>>     steadfast, because he trusts in you."               Isaiah 26:3
>>>                Tim Tautges            Argonne National Laboratory
>>>            (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>>    phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>>               fax: (608) 263-4499      Madison, WI 53706
