[MOAB-dev] r5970 - MOAB/trunk/src/parallel
iulian at mcs.anl.gov
Fri Feb 1 21:07:34 CST 2013
Author: iulian
Date: 2013-02-01 21:07:34 -0600 (Fri, 01 Feb 2013)
New Revision: 5970
Modified:
MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
a closing parantheses was misplaced during settling of the
intersection points; also remove a warning in printing a debug message;
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2013-02-01 22:58:16 UTC (rev 5969)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2013-02-02 03:07:34 UTC (rev 5970)
@@ -250,7 +250,7 @@
if (tag < MB_MESG_REMOTEH_ACK) myDebug->print(3, ", recv_ent_reqs=");
else if (tag < MB_MESG_TAGS_ACK) myDebug->print(3, ", recv_remoteh_reqs=");
else myDebug->print(3, ", recv_tag_reqs=");
- for (unsigned int i = 0; i < reqs.size(); i++) myDebug->printf(3, " %p", (void*)reqs[i]);
+ for (unsigned int i = 0; i < reqs.size(); i++) myDebug->printf(3, " %x", reqs[i]);
myDebug->print(3, "\n");
@@ -8794,12 +8794,14 @@
found =true;
break;
- if (!found)
- // warning ?
- result = MB_FAILURE;
+ if (!found)
+ std::cout<<" pk:" << pk[0] << " " << pk[1] << " " << pk[2] << " not found \n";
+ result = MB_FAILURE;
// after we are done resetting, we can set the new positions of nodes:
result = mbImpl->set_coords(&intx_nodes[0], nverts, ¤t_positions[0] );
