[MOAB-dev] Warnings in the code
Tim Tautges tautges at mcs.anl.gov
Thu Dec 6 14:20:36 CST 2012
On 12/06/2012 01:55 PM, Vijay S. Mahadevan wrote:
>> Going forward, I'm going to get more militant (read almost-zero-tolerance)
>> for warnings, at least from GCC builds.
> Fantastic !
>> We'll still probably get many Intel
>> warnings, since we don't have anybody building natively on that compiler
>> set.
> I build with the Intel compilers on several systems and I can take the
> responsibility to fix the warnings that are produced there. I will
> also configure a clang build to enforce rigorous standard compliance
> for at least the important bits of the code.
Thanks, that will help a lot.  If you only make it partway through fixing the warnings, feel free to send a dump of the
compile output to the list and we can divvy them up.
- tim
> Vijay
> On Thu, Dec 6, 2012 at 8:24 AM, Tim Tautges <tautges at mcs.anl.gov> wrote:
>> Hi all,
>>    I just turned on extensive warning reporting in MOAB's gnu-based builds,
>> and fixed a boatload of warnings in the code.  The ones that are left are
>> either because I was uncertain about whether they showed bugs (mostly the
>> ones in FBEngine) or because of C headers I didn't want to mess with right
>> now (findpt and related ones).
>> Those responsible for code having remaining warnings should look at them and
>> figure out whether they're spurious or not, and get rid of them.  If you're
>> uncertain about how to remove them, ask the list.
>> for warnings, at least from GCC builds. We'll still probably get many Intel
>> set.  But, one step at a time.
>> One thing I haven't fixed yet is warnings in test programs.  I'll assign
>> those to somebody soon.
>> Thanks.
>> - tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
