[MOAB-dev] Warnings in the code
Vijay S. Mahadevan vijay.m at gmail.com
Thu Dec 6 13:55:07 CST 2012
> Going forward, I'm going to get more militant (read almost-zero-tolerance)
> for warnings, at least from GCC builds.
Fantastic !
> We'll still probably get many Intel
> warnings, since we don't have anybody building natively on that compiler
> set.
I build with the Intel compilers on several systems and I can take the
responsibility to fix the warnings that are produced there. I will
also configure a clang build to enforce rigorous standard compliance
for at least the important bits of the code.
Vijay
On Thu, Dec 6, 2012 at 8:24 AM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> Hi all,
>   I just turned on extensive warning reporting in MOAB's gnu-based builds,
> and fixed a boatload of warnings in the code.  The ones that are left are
> either because I was uncertain about whether they showed bugs (mostly the
> ones in FBEngine) or because of C headers I didn't want to mess with right
> now (findpt and related ones).
> Those responsible for code having remaining warnings should look at them and
> figure out whether they're spurious or not, and get rid of them.  If you're
> uncertain about how to remove them, ask the list.
> for warnings, at least from GCC builds. We'll still probably get many Intel
> set.  But, one step at a time.
> One thing I haven't fixed yet is warnings in test programs.  I'll assign
> those to somebody soon.
> Thanks.
> - tim
