[MOAB-dev] r5896 - in MOAB/trunk: src/parallel test/parallel
iulian at mcs.anl.gov
Tue Dec 4 22:30:38 CST 2012
Author: iulian
Date: 2012-12-04 22:30:38 -0600 (Tue, 04 Dec 2012)
New Revision: 5896
Modified:
MOAB/trunk/src/parallel/ParallelComm.cpp
MOAB/trunk/test/parallel/ucdtrvpart.cpp
Log:
rename a variable used innapropriately in an inner loop.
Thank you Vijay, for pointing this out.
It was OK, as the compiler was much smarter than me:) and took care of things.
also, show what options could be used to multi-load an ucd nc file using trivial partition in a
typical scenario (1. read header 2. create mesh and resolve sharing 3. read a variable)
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2012-12-04 21:14:02 UTC (rev 5895)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2012-12-05 04:30:38 UTC (rev 5896)
@@ -4088,13 +4088,13 @@
indexInTuple++;
multishared_verts.inc_n();
// create more tuples, for each instance
- for (int k=startMulti; k<=endMulti; k++)
+ for (int k2=startMulti; k2<=endMulti; k2++)
multishared_verts.vi_wr[2*indexInTuple] = proc_to_send_to; // send to
- multishared_verts.vi_wr[2*indexInTuple+1] = remoting_entities.vi_wr[k]; // multi proc
- multishared_verts.vl_wr[indexInTuple] = remoting_entities.vl_wr[k]; // gid, for debug
+ multishared_verts.vi_wr[2*indexInTuple+1] = remoting_entities.vi_wr[k2]; // multi proc
+ multishared_verts.vl_wr[indexInTuple] = remoting_entities.vl_wr[k2]; // gid, for debug
multishared_verts.vul_wr[2*indexInTuple] = handle_with_multi; // remote handle on proc_to_send_to
- multishared_verts.vul_wr[2*indexInTuple+1] = remoting_entities.vul_wr[2*k]; // handle on multi proc
+ multishared_verts.vul_wr[2*indexInTuple+1] = remoting_entities.vul_wr[2*k2]; // handle on multi proc
indexInTuple++;
Modified: MOAB/trunk/test/parallel/ucdtrvpart.cpp
--- MOAB/trunk/test/parallel/ucdtrvpart.cpp 2012-12-04 21:14:02 UTC (rev 5895)
+++ MOAB/trunk/test/parallel/ucdtrvpart.cpp 2012-12-05 04:30:38 UTC (rev 5896)
@@ -26,7 +26,7 @@
result += RUN_TEST(test_read_parallel_ucd_trivial);
result += RUN_TEST(test_read_parallel_ucd_trivial_spectral);
- //result += RUN_TEST(test_multiple_loads_of_same_file);
+ result += RUN_TEST(test_multiple_loads_of_same_file);
MPI_Finalize();
return result;
@@ -106,16 +106,16 @@
CHECK_ERR(rval);
// read first only header information, no mesh, no variable
- std::string opts("PARALLEL=READ_PART;PARTITION;PARALLEL_GHOSTS=2.0.1;NOMESH;VARIABLE=;PARTITION_METHOD=TRIVIAL_PARTITION");
+ std::string opts("PARALLEL=READ_PART;PARTITION;NOMESH;VARIABLE=;PARTITION_METHOD=TRIVIAL_PARTITION");
rval = mb.load_file(example, &file_set, opts.c_str());
CHECK_ERR(rval);
- opts="PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1;PARTITION_METHOD=TRIVIAL_PARTITION;VARIABLE=";
+ opts="PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION_METHOD=TRIVIAL_PARTITION;VARIABLE=";
CHECK_ERR(rval);
