[MOAB-dev] r5897 - in MOAB/trunk: src/io src/parallel src/parallel/moab test/parallel
iulian at mcs.anl.gov
Wed Dec 5 09:45:14 CST 2012
Author: iulian
Date: 2012-12-05 09:45:14 -0600 (Wed, 05 Dec 2012)
New Revision: 5897
Removed:
MOAB/trunk/test/parallel/ucdnodpart.cpp
Modified:
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/io/ReadNC.hpp
MOAB/trunk/src/parallel/ParallelComm.cpp
MOAB/trunk/src/parallel/moab/ParallelComm.hpp
MOAB/trunk/test/parallel/Makefile.am
Log:
remove nodal partition option, there is not enough support for it :(
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2012-12-05 04:30:38 UTC (rev 5896)
+++ MOAB/trunk/src/io/ReadNC.cpp 2012-12-05 15:45:14 UTC (rev 5897)
@@ -37,7 +37,7 @@
mbImpl(impl), CPU_WORD_SIZE(-1), IO_WORD_SIZE(-1), fileId(-1), tMin(-1), tMax(-1), iDim(-1), jDim(-1), tDim(-1), iCDim(-1),
jCDim(-1), numUnLim(-1), mCurrentMeshHandle(0), startVertex(0), startElem(0), mGlobalIdTag(0), mpFileIdTag(NULL), max_line_length(-1),
max_str_length(-1), vertexOffset(0), dbgOut(stderr), isParallel(false), partMethod(-1), camType(NOT_CAM), isCf(false),
- spectralOrder(-1), npMesh(false),
+ spectralOrder(-1),
#ifdef USE_MPI
myPcomm(NULL),
#endif
@@ -202,14 +202,8 @@
ERRORR(rval, "Mesh characteristics didn't match from last read.\n");
else if (!noMesh) {
- if (-1 == partMethod && false) // not sure what to do with this...
- rval = create_np_verts_quads(opts, tmp_set, quads);
- else if (CAM_SE == camType) {
- if (npMesh)
- else
- rval = create_ucd_verts_quads(spectralMesh, opts, tmp_set, quads);
+ if (CAM_SE == camType)
+ rval = create_ucd_verts_quads(spectralMesh, opts, tmp_set, quads);
else
rval = create_verts_quads(scdi, tmp_set, quads);
ERRORR(rval, "Trouble creating vertices and quads.");
@@ -228,16 +222,6 @@
rval = mbImpl->get_entities_by_dimension(tmp_set, 0, local_verts);
if (MB_FAILURE == rval)
return rval;
-#ifdef USE_MPI
- if (npMesh && isParallel)
- // in parallel, for npMesh, we really need only owned vertices, which are contiguous!
- // this is the whole point of nodal partition :)
- rval = myPcomm->filter_pstatus(local_verts, PSTATUS_NOT_OWNED, PSTATUS_NOT);
- ERRORR(rval, "Trouble getting owned verts in set.");
-#endif
std::vector<int> gids(local_verts.size());
// !IMPORTANT : this has to be the GLOBAL_ID tag
rval=mbImpl->tag_get_data(mGlobalIdTag, local_verts, &gids[0]);
@@ -285,25 +269,6 @@
myPcomm->partition_sets().insert(partn_set);
