[MOAB-dev] Configure error with README.moabuse
    Milad Fatenejad
    icksa1 at gmail.com
    Mon Oct 22 16:12:58 CDT 2012
Hi Vijay:
OK, I just removed all references to moabuse from configure.ac. So if you
pull and run autoconf again, things should be ok.
So, the idea was that these files would get copied into the install
directory. I spoke to Iulian today and realized that I kind of screwed this
up. The way it is set up now, the files will get copied into the build
directory. You are correct that the write thing to do is create a
Makefile.am and work with that. I am new to autoconf and made a lot of
mistakes, so my hope is to just disable all of this until I can learn more.
My apologies.
Milad
On Mon, Oct 22, 2012 at 3:51 PM, Vijay S. Mahadevan <vijay.m at gmail.com>wrote:
> Milad,
> I still get the same configure error after pulling your latest
> changes. I now have a README.moabuse.in but looks like you need to
> update configure or add Makefile.am for the changes to take effect.
> config.status: error: cannot find input file:
> examples/moabuse/README.moabuse
> [vijaysm at janus moab-dev] ls examples/moabuse/
> Makefile  Makefile.in  mberr.hpp.in  moabuse1.cpp.in  moabuse2.cpp.in
> moabuse3.cpp.in  moabuse4.cpp.in  README.moabuse.in
> As Iulian pointed out, why are these configure time files anyway and
> not just sources that get compiled during make ? The hpp/cpp files
> dont need to be inspected during configure and it is unnecessary.
> Vijay
> On Mon, Oct 22, 2012 at 2:52 PM, Milad Fatenejad <icksa1 at gmail.com> wrote:
> > Hi Vijay:
> > Sorry, this was my fault. I just checked in a fix.
> > Milad
> > On Mon, Oct 22, 2012 at 2:37 PM, Vijay S. Mahadevan <vijay.m at gmail.com>
> > wrote:
> >> While updating the repository to the latest version, I pulled and
> >> re-configured with the command below but the configure process gives
> >> an error message now and stops.
> >> ./configure --prefix=/home/vijaysm/software/opt/moab
> >> --with-hdf5=/home/jain/hdf5-1.8.9 --disable-debug --enable-optimize
> >> --with-mpi=/soft/mvapich2/1.5.1p1/intel/11.1.059 --enable-mbcoupler
> >> --enable-mbpart --enable-mbsize
> >> --with-netcdf=/home/jain/lib/netcdf-4.1.2
> >> --with-zoltan=/home/jain/lib/Zoltan_v3.3
> >> --with-parmetis=/home/jain/ParMETIS3_1
> >> checking build system type... x86_64-unknown-linux-gnu
> >> config.status: creating examples/moabuse/Makefile
> >> config.status: creating examples/moabuse/README.moabuse
> >> When I do an svn up again, I get
> >> Restored 'examples/moabuse/README.moabuse'.
> >> Perhaps somewhere inside configure, the README file is being deleted
> >> (I checked Makefile.in and it is part of the Clean files). Also I dont
> >> understand the logic for adding a README file as part of the configure
> >> process. This seems to be static and a reconfigure wipes it out. Is
> >> there a README.moabuse.in that is not in the repository ? Let me know
> >> if you need config.log for more details.
> >> Thanks,
> >> Vijay
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20121022/90627981/attachment.html>
