[MOAB-dev] Configure error with README.moabuse
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Mon Oct 22 15:51:51 CDT 2012
Milad,
I still get the same configure error after pulling your latest
changes. I now have a README.moabuse.in but looks like you need to
update configure or add Makefile.am for the changes to take effect.
config.status: error: cannot find input file: examples/moabuse/README.moabuse
[vijaysm at janus moab-dev] ls examples/moabuse/
Makefile  Makefile.in  mberr.hpp.in  moabuse1.cpp.in  moabuse2.cpp.in
moabuse3.cpp.in  moabuse4.cpp.in  README.moabuse.in
As Iulian pointed out, why are these configure time files anyway and
not just sources that get compiled during make ? The hpp/cpp files
dont need to be inspected during configure and it is unnecessary.
Vijay
On Mon, Oct 22, 2012 at 2:52 PM, Milad Fatenejad <icksa1 at gmail.com> wrote:
> Hi Vijay:
> Sorry, this was my fault. I just checked in a fix.
> Milad
> On Mon, Oct 22, 2012 at 2:37 PM, Vijay S. Mahadevan <vijay.m at gmail.com>
> wrote:
>> While updating the repository to the latest version, I pulled and
>> re-configured with the command below but the configure process gives
>> an error message now and stops.
>> ./configure --prefix=/home/vijaysm/software/opt/moab
>> --with-hdf5=/home/jain/hdf5-1.8.9 --disable-debug --enable-optimize
>> --with-mpi=/soft/mvapich2/1.5.1p1/intel/11.1.059 --enable-mbcoupler
>> --enable-mbpart --enable-mbsize
>> --with-netcdf=/home/jain/lib/netcdf-4.1.2
>> --with-zoltan=/home/jain/lib/Zoltan_v3.3
>> --with-parmetis=/home/jain/ParMETIS3_1
>> checking build system type... x86_64-unknown-linux-gnu
>> config.status: creating examples/moabuse/Makefile
>> config.status: creating examples/moabuse/README.moabuse
>> When I do an svn up again, I get
>> Restored 'examples/moabuse/README.moabuse'.
>> Perhaps somewhere inside configure, the README file is being deleted
>> (I checked Makefile.in and it is part of the Clean files). Also I dont
>> understand the logic for adding a README file as part of the configure
>> process. This seems to be static and a reconfigure wipes it out. Is
>> there a README.moabuse.in that is not in the repository ? Let me know
>> if you need config.log for more details.
>> Thanks,
>> Vijay
