[MOAB-dev] Configure error with README.moabuse
    Milad Fatenejad
    icksa1 at gmail.com
    Mon Oct 22 14:52:26 CDT 2012
Hi Vijay:
Sorry, this was my fault. I just checked in a fix.
Milad
On Mon, Oct 22, 2012 at 2:37 PM, Vijay S. Mahadevan <vijay.m at gmail.com>wrote:
> While updating the repository to the latest version, I pulled and
> re-configured with the command below but the configure process gives
> an error message now and stops.
> ./configure --prefix=/home/vijaysm/software/opt/moab
> --with-hdf5=/home/jain/hdf5-1.8.9 --disable-debug --enable-optimize
> --with-mpi=/soft/mvapich2/1.5.1p1/intel/11.1.059 --enable-mbcoupler
> --enable-mbpart --enable-mbsize
> --with-netcdf=/home/jain/lib/netcdf-4.1.2
> --with-zoltan=/home/jain/lib/Zoltan_v3.3
> --with-parmetis=/home/jain/ParMETIS3_1
> checking build system type... x86_64-unknown-linux-gnu
> config.status: creating examples/moabuse/Makefile
> config.status: creating examples/moabuse/README.moabuse
> config.status: error: cannot find input file:
> When I do an svn up again, I get
> Restored 'examples/moabuse/README.moabuse'.
> Perhaps somewhere inside configure, the README file is being deleted
> (I checked Makefile.in and it is part of the Clean files). Also I dont
> understand the logic for adding a README file as part of the configure
> process. This seems to be static and a reconfigure wipes it out. Is
> there a README.moabuse.in that is not in the repository ? Let me know
> if you need config.log for more details.
> Thanks,
> Vijay
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20121022/2476e5ee/attachment.html>
