[MOAB-dev] --enable-igeom vs. --disable-imesh
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Wed May 30 17:12:34 CDT 2012
Hi, you are right, the buildbot does not test --enable-igeom. Maybe we should be more clear about what igeom means in moab. Also, --enable-igeom actually means that the moab implementation of igeom will be build (which is incomplete, by the way) I think that you want to build with cgm, and enable-imesh. You will get igeom support through cgm. moab/itaps/igeom really tests mesh-based geometry created using moab conventions (so, the "geometry" is in a h5m file) It cannot read directly brep or sat files. Yes, probably make check should do nothing in igeom folder if it was disabled. But it will not go there if you run make check from the root folder. Iulian ----- Original Message -----
| Hi MOAB Developers,
| I think by default MOAB builds WITH iMesh support and so the configure
| option is to disable it with --disable-imesh.
| However, I just build 4.5 branch and did NOT specify --enable-igeom
| (such as './configure --help' indicates is necessary for iGeom
| support)
| and nonetheless, I am still able to compile iGeom clients in
| itaps/igeom
| directory.
| I mention it only because I am wondering if there are one or two
| issues
| here?
| Does MOAB build iGeom by default too? If so, the configure switch for
| it
| probably ought to be --disable-igeom much as it is for iMesh support.
| If MOAB doesn't build iGeom by default, how is it that 'make check' in
| itaps/igeom dir succeeded in building iGeom clients?
| Mark
| Mark C. Miller, Lawrence Livermore National Laboratory
| ================!!LLNL BUSINESS ONLY!!================
| miller86 at llnl.gov urgent: miller86 at pager.llnl.gov
| T:8-6 (925)-423-5901 M/W/Th:7-12,2-7 (530)-753-8511
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120530/9adba80a/attachment-0001.html>
