[MOAB-dev] --enable-igeom vs. --disable-imesh
    Mark Miller
    miller86 at llnl.gov
    Wed May 30 16:47:03 CDT 2012
Hi MOAB Developers,
I think by default MOAB builds WITH iMesh support and so the configure
option is to disable it with --disable-imesh.
However, I just build 4.5 branch and did NOT specify --enable-igeom
(such as './configure --help' indicates is necessary for iGeom support)
and nonetheless, I am still able to compile iGeom clients in itaps/igeom
directory.
I mention it only because I am wondering if there are one or two issues
here?
Does MOAB build iGeom by default too? If so, the configure switch for it
probably ought to be --disable-igeom much as it is for iMesh support.
If MOAB doesn't build iGeom by default, how is it that 'make check' in
itaps/igeom dir succeeded in building iGeom clients?
Mark C. Miller, Lawrence Livermore National Laboratory
================!!LLNL BUSINESS ONLY!!================
miller86 at llnl.gov      urgent: miller86 at pager.llnl.gov
T:8-6 (925)-423-5901    M/W/Th:7-12,2-7 (530)-753-8511
