[MOAB-dev] r5412 - MOAB/trunk/src/moab
xbxu at mcs.anl.gov
xbxu at mcs.anl.gov
Wed Feb 29 15:23:31 CST 2012
Author: xbxu
Date: 2012-02-29 15:23:30 -0600 (Wed, 29 Feb 2012)
New Revision: 5412
Modified:
MOAB/trunk/src/moab/ScdInterface.hpp
Log:
set local ijk values to be global ijk values for sqij partition method when running in serial
Modified: MOAB/trunk/src/moab/ScdInterface.hpp
--- MOAB/trunk/src/moab/ScdInterface.hpp 2012-02-28 16:27:09 UTC (rev 5411)
+++ MOAB/trunk/src/moab/ScdInterface.hpp 2012-02-29 21:23:30 UTC (rev 5412)
@@ -771,40 +771,51 @@
// square IxJ partition
- std::vector<double> pfactors, ppfactors;
- for (int i = 2; i <= np; i++)
- if (!(np%i)) {
- pfactors.push_back(i);
- ppfactors.push_back(((double)(i*i))/np);
+ if (np == 1) {
+ if (lijk) {
+ lijk[0] = gijk[0];
+ lijk[3] = gijk[3];
+ lijk[1] = gijk[1];
+ lijk[4] = gijk[4];
+ lijk[2] = gijk[2];
+ lijk[5] = gijk[5];
+ else {
+ std::vector<double> pfactors, ppfactors;
+ for (int i = 2; i <= np; i++)
+ if (!(np%i)) {
+ pfactors.push_back(i);
+ ppfactors.push_back(((double)(i*i))/np);
// ideally, Px/Py = I/J
- double ijratio = ((double)(gijk[3]-gijk[0]))/((double)(gijk[4]-gijk[1]));
- unsigned int ind = std::lower_bound(ppfactors.begin(), ppfactors.end(), ijratio) - ppfactors.begin();
- if (ind && fabs(ppfactors[ind-1]-ijratio) < fabs(ppfactors[ind]-ijratio)) ind--;
- int pi = pfactors[ind];
- int pj = np / pi;
- int I = (gijk[3] - gijk[0]), J = (gijk[4] - gijk[1]);
- int iextra = I%pi, jextra = J%pj, i = I/pi, j = J/pj;
- int nri = nr % pi, nrj = nr / pi;
-// pi, pj = # blocks in i, j directions
-// nri, nrj = column, row of this processor's block
- if (lijk) {
- lijk[0] = i*nri + std::min(iextra, nri);
- lijk[3] = lijk[0] + i + (nri < iextra ? 1 : 0);
- lijk[1] = j*nrj + std::min(jextra, nrj);
