[MOAB-dev] iMesh & iGeom
    Christopher Mueller
    cmueller at asascience.com
    Sun Feb 26 09:22:15 CST 2012
Sounds great - thanks Tim.
Chris
From: Tim Tautges <tautges at mcs.anl.gov<mailto:tautges at mcs.anl.gov>>
Date: Sat, 25 Feb 2012 13:51:11 -0500
To: Christopher Mueller <cmueller at asascience.com<mailto:cmueller at asascience.com>>
Cc: "moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov>" <moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov>>, Guy De Wardener <gdewardener at asascience.com<mailto:gdewardener at asascience.com>>, David Stuebe <DStuebe at asascience.com<mailto:DStuebe at asascience.com>>, don brittain <don.brittain at instanteffects.com<mailto:don.brittain at instanteffects.com>>
Subject: Re: [MOAB-dev] iMesh & iGeom
No, but once the "fairly soon" thing I'm referring to gets done, which will be before summer, there'll be a pytaps path
to it.  Note, though, that it'll still be limited functionality; we don't plan to fill out all the capability based on mesh.
- tim
On 02/25/2012 11:16 AM, Christopher Mueller wrote:
Is FBiGeom available via PyTAPS at this point?
Chris
From: Tim Tautges <tautges at mcs.anl.gov<mailto:tautges at mcs.anl.gov> <mailto:tautges at mcs.anl.gov>>
Date: Sat, 25 Feb 2012 11:36:21 -0500
To: Christopher Mueller <cmueller at asascience.com<mailto:cmueller at asascience.com> <mailto:cmueller at asascience.com>>
Cc: "moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov> <mailto:moab-dev at mcs.anl.gov>" <moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov> <mailto:moab-dev at mcs.anl.gov>>, Guy De
Wardener <gdewardener at asascience.com<mailto:gdewardener at asascience.com> <mailto:gdewardener at asascience.com>>, David Stuebe <DStuebe at asascience.com<mailto:DStuebe at asascience.com>
<mailto:DStuebe at asascience.com>>, don brittain <don.brittain at instanteffects.com<mailto:don.brittain at instanteffects.com> <mailto:don.brittain at instanteffects.com>>
     Some of the functions are implemented in tools/FBiGeom (FB stands for facet-based); fairly soon there should be an
     implementation of the iGeom interface that you can call like any other iGeom implementation.
     - tim
     On 02/25/2012 10:20 AM, Christopher Mueller wrote:
         Hi Tim/all,
         I may be missing something obvious or I may be trying something that's not even possible, but how does one use
         the iGeom
         functions against a mesh created with iMesh?
         Chris
     steadfast, because he trusts in you." Isaiah 26:3
     Tim Tautges Argonne National Laboratory
     (tautges at mcs.anl.gov<mailto:tautges at mcs.anl.gov> <mailto:tautges at mcs.anl.gov>) (telecommuting from UW-Madison)
     phone (gvoice): (608) 354-1459 1500 Engineering Dr.
     fax: (608) 263-4499 Madison, WI 53706
          (tautges at mcs.anl.gov<mailto:tautges at mcs.anl.gov>)      (telecommuting from UW-Madison)
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120226/8d8b991d/attachment.htm>
