[MOAB-dev] iMesh & iGeom
    Tim Tautges
    tautges at mcs.anl.gov
    Sat Feb 25 12:51:11 CST 2012
No, but once the "fairly soon" thing I'm referring to gets done, which will be before summer, there'll be a pytaps path
to it.  Note, though, that it'll still be limited functionality; we don't plan to fill out all the capability based on mesh.
- tim
On 02/25/2012 11:16 AM, Christopher Mueller wrote:
> Is FBiGeom available via PyTAPS at this point?
> Chris
> From: Tim Tautges <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>>
> Date: Sat, 25 Feb 2012 11:36:21 -0500
> To: Christopher Mueller <cmueller at asascience.com <mailto:cmueller at asascience.com>>
> Cc: "moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>" <moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>>, Guy De
> Wardener <gdewardener at asascience.com <mailto:gdewardener at asascience.com>>, David Stuebe <DStuebe at asascience.com
> <mailto:DStuebe at asascience.com>>, don brittain <don.brittain at instanteffects.com <mailto:don.brittain at instanteffects.com>>
> Subject: Re: [MOAB-dev] iMesh & iGeom
>     Some of the functions are implemented in tools/FBiGeom (FB stands for facet-based); fairly soon there should be an
>     implementation of the iGeom interface that you can call like any other iGeom implementation.
>     - tim
>     On 02/25/2012 10:20 AM, Christopher Mueller wrote:
>         Hi Tim/all,
>         I may be missing something obvious or I may be trying something that's not even possible, but how does one use
>         the iGeom
>         functions against a mesh created with iMesh?
>         Thanks,
>         Chris
>     "You will keep in perfect peace him whose mind is
>     steadfast, because he trusts in you." Isaiah 26:3
>     Tim Tautges Argonne National Laboratory
>     (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>) (telecommuting from UW-Madison)
>     phone (gvoice): (608) 354-1459 1500 Engineering Dr.
>     fax: (608) 263-4499 Madison, WI 53706
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
