[MOAB-dev] r5390 - MOAB/trunk/tools/dagmc
sjackson at cae.wisc.edu
Fri Feb 10 15:46:10 CST 2012
Author: sjackson
Date: 2012-02-10 15:46:10 -0600 (Fri, 10 Feb 2012)
New Revision: 5390
Modified:
MOAB/trunk/tools/dagmc/DagMC.cpp
Log:
Work around an issue in DagMC::entity_by_id()
This function did not behave as expected on reloaded
geometries from older versions of DagMC.
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2012-02-10 18:30:46 UTC (rev 5389)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2012-02-10 21:46:10 UTC (rev 5390)
@@ -1404,8 +1404,19 @@
Range results;
rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, results );
- if (MB_SUCCESS != rval || results.empty())
- return 0;
+ if ( MB_SUCCESS != rval )
+ return 0;
+ if ( results.empty() ){
+ // old versions of dagmc did not set tags correctly on the implicit complement 'volume',
+ // causing it to not be found by the call above. This check allows this function to work
+ // correctly, even on reloaded files from older versions.
+ if( dimension == 3 && get_entity_id(impl_compl_handle) == id )
+ return impl_compl_handle;
+ else
+ return 0;
return results.front();
