[MOAB-dev] r5381 - in MOAB/trunk/src/parallel: . moab
hongjun at mcs.anl.gov
Tue Feb 7 14:53:48 CST 2012
Author: hongjun
Date: 2012-02-07 14:53:47 -0600 (Tue, 07 Feb 2012)
New Revision: 5381
Modified:
MOAB/trunk/src/parallel/ParallelComm.cpp
MOAB/trunk/src/parallel/moab/ParallelComm.hpp
Log:
o "send_entities", "recv_entities" and "post_irecv" functions are added
o They are used for send and recv meshes separately and can do mesh generation during communication
o passes make check
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2012-02-07 18:26:59 UTC (rev 5380)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2012-02-07 20:53:47 UTC (rev 5381)
@@ -701,6 +701,125 @@
#endif
+ErrorCode ParallelComm::send_entities(std::vector<unsigned int>& send_procs,
+ std::vector<Range*>& send_ents,
+ int& incoming1, int& incoming2,
+ const bool store_remote_handles)
+#ifdef USE_MPE
+ if (myDebug->get_verbosity() == 2) {
+ MPE_Log_event(OWNED_START, procConfig.proc_rank(), "Starting send entities.");
+#endif
+ myDebug->tprintf(1, "Entering send_entities\n");
+ if (myDebug->get_verbosity() == 4) {
+ msgs.clear();
+ msgs.reserve(MAX_SHARING_PROCS);
+ unsigned int i;
+ int ind, success;
+ ErrorCode result = MB_SUCCESS;
+ // set buffProcs with communicating procs
+ unsigned int n_proc = send_procs.size();
+ for (i = 0; i < n_proc; i++) {
+ ind = get_buffers(send_procs[i]);
+ result = add_verts(*send_ents[i]);
+ RRA("Couldn't add verts.");
+ // filter out entities already shared with destination
+ Range tmp_range;
+ result = filter_pstatus(*send_ents[i], PSTATUS_SHARED, PSTATUS_AND,
+ buffProcs[ind], &tmp_range);
+ RRA("Couldn't filter on owner.");
+ if (!tmp_range.empty()) {
+ *send_ents[i] = subtract(*send_ents[i], tmp_range);
+ // get entities to be sent to neighbors
+ // need to get procs each entity is sent to
+ Range allsent, tmp_range;
+ int dum_ack_buff;
