[MOAB-dev] Does iMesh_getEntAdj return entities in the canonical connectivity order?
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Fri Jan 27 11:12:45 CST 2012
moab::Range is not used, it will get vertices in the canonical order ----- Original Message -----
| Jim, could you check the implementation of this in iMesh_MOAB? I think
| it depends on whether a range is used or not...
| - tim
| On 01/27/2012 10:53 AM, Stuart Slattery wrote:
| > Hi all,
| > Say I make a hexahedron element out of 8 vertices in canonical order
| > with iMesh_createEnt. If I call iMesh_getEntAdj on
| > that hexahedron and ask for vertices, should I always get the
| > vertices back in canonical order?
| > Thanks
| > Stuart
| "You will keep in perfect peace him whose mind is
| steadfast, because he trusts in you." Isaiah 26:3
| Tim Tautges Argonne National Laboratory
| (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
| phone (gvoice): (608) 354-1459 1500 Engineering Dr.
| fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120127/887b6cc7/attachment.htm>
