[MOAB-dev] Does iMesh_getEntAdj return entities in the canonical connectivity order?
    Stuart Slattery
    sslattery at wisc.edu
    Fri Jan 27 11:14:09 CST 2012
On 01/27/2012 11:12 AM, Iulian Grindeanu wrote:
> moab::Range is not used, it will get vertices in the canonical order
Thanks. I'll check this out in my unit tests and let you know if this
isn't the case.
Stuart
>     Jim, could you check the implementation of this in iMesh_MOAB?  I
>     think it depends on whether a range is used or not...
>     - tim
>     On 01/27/2012 10:53 AM, Stuart Slattery wrote:
>     > Hi all,
>     > Say I make a hexahedron element out of 8 vertices in canonical
>     order with iMesh_createEnt. If I call iMesh_getEntAdj on
>     > that hexahedron and ask for vertices, should I always get the
>     vertices back in canonical order?
>     > Thanks
>     > Stuart
>     "You will keep in perfect peace him whose mind is
>        steadfast, because he trusts in you."               Isaiah 26:3
>                   Tim Tautges            Argonne National Laboratory
>               (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>       phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>                  fax: (608) 263-4499      Madison, WI 53706
Stuart Slattery
Graduate Research Assistant
Computational Nuclear Engineering Research Group
Department of Engineering Physics
University of Wisconsin - Madison
434 Engineering Research Building
1500 Engineering Drive
Madison, WI 53706
email : sslattery at wisc.edu
Phone : 608.263.1709
url   : http://cnerg.engr.wisc.edu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120127/25998183/attachment.htm>
