[MOAB-dev] Does iMesh_getEntAdj return entities in the canonical connectivity order?
Tim Tautges tautges at mcs.anl.gov
Fri Jan 27 10:57:41 CST 2012
Jim, could you check the implementation of this in iMesh_MOAB?  I think it depends on whether a range is used or not...
- tim
On 01/27/2012 10:53 AM, Stuart Slattery wrote:
> Hi all,
> Say I make a hexahedron element out of 8 vertices in canonical order with iMesh_createEnt. If I call iMesh_getEntAdj on
> that hexahedron and ask for vertices, should I always get the vertices back in canonical order?
> Thanks
> Stuart
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
