[MOAB-dev] [cgma-dev] question about iges format (to Jane)
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Fri Jan 20 10:02:58 CST 2012
----- Original Message -----
| I'd think for now, without any GUI connected, the best way is to add
| in the iGeom_load function, an unit option in the 'options' which
| indicate the unit (Acis will ignore this). This way users of cgm on
| OCC will have the control. I'll implement this way then.
| Jane
Thanks Jane, I think this is a good solution. So the option will be used only when CGM is built with OCC? There is still the problem with faceting in MOAB, maybe there is an option to pass that option from MOAB to CGM loading. Does anybody know? Best Regards, Iulian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120120/68bba348/attachment.htm>
