[MOAB-dev] r5326 - in MOAB/trunk: src test
iulian at mcs.anl.gov
Fri Jan 20 08:24:08 CST 2012
Author: iulian
Date: 2012-01-20 08:24:05 -0600 (Fri, 20 Jan 2012)
New Revision: 5326
Modified:
MOAB/trunk/src/FBEngine.cpp
MOAB/trunk/test/crop_vol_test.cpp
MOAB/trunk/test/mbfacet_test.cpp
MOAB/trunk/test/mbground_test.cpp
Log:
Modify the splitting logic, so the boundary edges will always have to be
crossed by the polyline. In other words, the polyline has to end outside of
the face that is splitted by a "grounding line" type.
Cropping will always involve a loop completely inside a face.
Also, pass the min_dot parameter to tests, so the topology can be kept
at a minimum
Modified: MOAB/trunk/src/FBEngine.cpp
--- MOAB/trunk/src/FBEngine.cpp 2012-01-19 17:19:26 UTC (rev 5325)
+++ MOAB/trunk/src/FBEngine.cpp 2012-01-20 14:24:05 UTC (rev 5326)
@@ -1216,6 +1216,13 @@
CartVect perpDir = dirct*normPlane;
Range::iterator ite=boundary_mesh_edges.begin();
// do a linear search for the best intersection point position (on a boundary edge)
+ if (debug_splits)
+ std::cout << " p1:" << p1 <<"\n";
+ std::cout << " p2:" << p2 <<"\n";
+ std::cout << " perpDir:" << perpDir << "\n";
+ std::cout<<" boundary edges size:" << boundary_mesh_edges.size() << "\n";
for ( ; ite!=boundary_mesh_edges.end(); ite++)
EntityHandle candidateEdge = *ite;
@@ -1230,12 +1237,18 @@
double parPos;
bool intersect = intersect_segment_and_plane_slice(pts[0], pts[1],
p1, p2, dirct, normPlane, intx_point, parPos);
+ if (debug_splits)
+ std::cout << " Edge:" << _mbImpl->id_from_handle(candidateEdge)<<"\n";
+ std::cout << " Node 1:" << _mbImpl->id_from_handle(conn2[0]) << pts[0] <<"\n";
+ std::cout << " Node 2:" << _mbImpl->id_from_handle(conn2[1]) << pts[1] <<"\n";
+ std::cout << " Intersect bool:" << intersect << "\n";
if (intersect)
double proj1 = (intx_point-p1)%perpDir;
double proj2 = (intx_point-p2)%perpDir;
- if ( (proj1*proj2>0) // this means outside of the imaginary p1 - p2 segment in xy plane
+ if (
( fabs(proj1) > fabs(proj2) ) // this means it is closer to p2 than p1
continue; // basically, this means the intersection point is with a
Modified: MOAB/trunk/test/crop_vol_test.cpp
--- MOAB/trunk/test/crop_vol_test.cpp 2012-01-19 17:19:26 UTC (rev 5325)
+++ MOAB/trunk/test/crop_vol_test.cpp 2012-01-20 14:24:05 UTC (rev 5326)
@@ -30,7 +30,7 @@
std::string filename_top;
std::string filename_bot;
std::string polygon_file_name;
+double min_dot = 0.8;
std::string vol_file;
