[MOAB-dev] [cgma-dev] question about iges format (to Jane)
    Jane Hu
    janejhu at gmail.com
    Fri Jan 20 12:30:43 CST 2012
On Fri, Jan 20, 2012 at 10:02 AM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
> I'd think for now, without any GUI connected, the best way is to add in
> the iGeom_load function, an unit option in the 'options' which indicate the
> unit (Acis will ignore this). This way users of cgm on OCC will have the
> control. I'll implement this way then.
> Jane
> Thanks Jane,
> I think this is a good solution. So the option will be used only when CGM
> is built with OCC?
Yes, all geometry engine will have this unit argument for importing and
exporting, just cgm_OCC will actually use this argument.
Jane
There is still the problem with faceting in MOAB, maybe there is an option
> to pass that option from MOAB to CGM loading. Does anybody know?
> Best Regards,
> Iulian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120120/71bd4bb7/attachment.htm>
