[MOAB-dev] moab::ReadUtilIface
Iulian Grindeanu iulian at mcs.anl.gov
Wed Oct 19 14:36:10 CDT 2011
OK, Sorry for the noise,
It seems that there is a
ErrorCode update_adjacencies(
const EntityHandle start_handle,
const int number_elements,
const int number_vertices_per_element,
const EntityHandle* conn_array
) = 0;
method in ReadUtilIFace..
Iulian
----- Original Message -----
Hello,
I have a question about the difference in create_element and ReadUtilIFace.
we use ReadUtilIFace in MeshKit to create new element meshes.
It is more efficient, but there is drawback; the adjacency is not recomputed for the new elements; there is no notification sent to AEntityFactory to update adjacency for newly created elements (like the one in ErrorCode Core::create_element(const EntityType type,
const EntityHandle *connectivity,
const int num_nodes,
EntityHandle &handle))
What is the correct way of doing it?
If we need adjacency?
In my scenario, I created new triangles, but after that, I needed the Skinner. It failed, because there were no adjacencies between new nodes and new triangles.
I can always change the code to use "create_element", but is there a way to force recomputation of adjacencies after using ReadUtilIFace?
Iulian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20111019/5082165e/attachment.htm>
