[MOAB-dev] Make check failure using Intel compiler on fusion r5160
Xiabing Xu xbxu at mcs.anl.gov
Wed Sep 14 11:27:07 CDT 2011
It seems that the functor name is a typo, should be less_vect instead of less_vect_indr at line 136 in SharedSetData.hpp.
My configuration:
./configure --prefix=/homes/xbxu/parvis/moab-performance/install --with-mpi=/soft/mvapich2/1.4.1-intel-11.1.064 --with-pnetcdf=/fusion/group/climate/software/pnetcdf/parallel-netcdf-1.2.0/install --with-netcdf=/fusion/group/climate/software/netcdf/netcdf-4.1.2-parallel/install --with-hdf5=/fusion/group/climate/software/hdf5/hdf5-1.8.6-parallel/install --with-zlib=/fusion/group/climate/software/zlib/zlib-1.2.5/install --with-szip=/fusion/group/climate/software/szip/szip-2.1/install --enable-optimize --disable-fortran CC=/soft/mvapich2/1.4.1-intel-11.1.064/bin/mpicc CXX=/soft/mvapich2/1.4.1-intel-11.1.064/bin/mpicxx
Error messages:
make[5]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-performance/src/parallel'
/bin/sh ../../libtool  --tag=CXX   --mode=compile /soft/mvapich2/1.4.1-intel-11.1.064/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src  -I/fusion/group/climate/software/pnetcdf/parallel-netcdf-1.2.0/install/include -I/fusion/group/climate/software/netcdf/netcdf-4.1.2-parallel/install/include   -I/fusion/group/climate/software/hdf5/hdf5-1.8.6-parallel/install/include -isystem /fusion/group/climate/software/hdf5/hdf5-1.8.6-parallel/install/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DPNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -I./.. -I.. -I./../io -I./../io/mhdf/include   -Wall -wd981 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -MT ParallelComm.lo -MD -MP -MF .deps/ParallelComm.Tpo -c -o ParallelComm.lo ParallelComm.cpp
libtool: compile:  /soft/mvapich2/1.4.1-intel-11.1.064/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src -I/fusion/group/climate/software/pnetcdf/parallel-netcdf-1.2.0/install/include -I/fusion/group/climate/software/netcdf/netcdf-4.1.2-parallel/install/include -I/fusion/group/climate/software/hdf5/hdf5-1.8.6-parallel/install/include -isystem /fusion/group/climate/software/hdf5/hdf5-1.8.6-parallel/install/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DPNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -I./.. -I.. -I./../io -I./../io/mhdf/include -Wall -wd981 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -MT ParallelComm.lo -MD -MP -MF .deps/ParallelComm.Tpo -c ParallelComm.cpp -o ParallelComm.o
SharedSetData.hpp(136): error: identifier "less_vect_indr" is undefined
    typedef std::set<std::vector<unsigned>,less_vect_indr> RProcMap;
ParallelComm.cpp(6868): remark #869: parameter "create_if_missing" was never referenced
                                  bool create_if_missing)
errmem.h(52): remark #177: function "buffer_reserve_" was declared but never referenced
  static void buffer_reserve_(buffer *b, size_t min, const char *file)
tuple_list.h(62): remark #177: function "tuple_list_grow" was declared but never referenced
  static void tuple_list_grow(tuple_list *tl)
compilation aborted for ParallelComm.cpp (code 2)
Xiabing
