[MOAB-dev] r5157 - MOAB/trunk/src/io
xbxu at mcs.anl.gov xbxu at mcs.anl.gov
Fri Sep 9 09:46:08 CDT 2011
Author: xbxu
Date: 2011-09-09 09:46:07 -0500 (Fri, 09 Sep 2011)
New Revision: 5157
Modified:
   MOAB/trunk/src/io/ReadNC.cpp
Log:
o create nc conventional tags only when loading header info
o fix the bug to read correct time steps when specific time steps are
specified
o only create dim_name tag for lat, lon, lev and time for now
o treat variable names lat, lon etc. as a single dimension variable
o passes make check in serial and parallel.
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp	2011-09-08 21:03:29 UTC (rev 5156)
+++ MOAB/trunk/src/io/ReadNC.cpp	2011-09-09 14:46:07 UTC (rev 5157)
@@ -192,10 +192,12 @@
   mbImpl->release_interface(scdi);
   ERRORR(rval, "Trouble creating scd element sequence.");
-    // create nc conventional tags
-  rval = create_tags(scdi, tmp_set, tstep_nums);
-  ERRORR(rval, "Trouble creating nc conventional tags.");
+    // create nc conventional tags when loading header info only
+  if (nomesh && novars) {
+    rval = create_tags(scdi, tmp_set, tstep_nums);
+    ERRORR(rval, "Trouble creating nc conventional tags.");
   return MB_SUCCESS;
@@ -470,7 +472,7 @@
         // set up the dimensions and counts
         // first time
-      vdatas[i].readDims[t].push_back(t);
+      vdatas[i].readDims[t].push_back(tstep_nums[t]);
       vdatas[i].readCounts[t].push_back(1);
         // then z/y/x
@@ -1107,9 +1109,9 @@
       val = &klVals[0];
     else if (tag_name == "time")
       val = &tVals[0];
-    else {
+    else
       continue;
     Tag tagh = 0;
     DataType data_type;
     int val_len = dimVals[i];
@@ -1171,43 +1173,46 @@
   for (unsigned int i = 0; i != dimNamesSz; ++i) {
     if (dimNames[i] != "time")
       continue;
-    if (!tstep_nums.empty()) {
-      Tag tagh = 0;
-      std::vector<int> val = tstep_nums;
-      std::stringstream ss_tag_name;
-      ss_tag_name << "__" << dimNames[i] << "_LOC_VALS";
