[MOAB-dev] Make check failure using Intel compiler on fusion r5160
Iulian Grindeanu
iulian at mcs.anl.gov
Thu Sep 15 09:35:04 CDT 2011
Hi Xiabing,
I think you are right, the code should be changed as you suggested.
I do not have a fusion account, but if make check passes on intel fusion compiler with your change, you should commit it.
Notice that the error does not show up on newer compilers, for which our HAVE_UNORDERED_MAP flag is defined
--- SharedSetData.hpp (revision 5160)
+++ SharedSetData.hpp (working copy)
@@ -133,7 +133,7 @@
typedef std::map<unsigned,ProcHandleMapType> RHMap;
- typedef std::set<std::vector<unsigned>,less_vect_indr> RProcMap;
+ typedef std::set<std::vector<unsigned>,less_vect> RProcMap;
#endif
/** Map for lookup of ProcHandleMapType instance by rank */
Best Regards,
Iulian
----- Original Message -----
> It seems that the functor name is a typo, should be less_vect instead
> of less_vect_indr at line 136 in SharedSetData.hpp.
> My configuration:
> ./configure --prefix=/homes/xbxu/parvis/moab-performance/install
> --with-mpi=/soft/mvapich2/1.4.1-intel-11.1.064
> --with-pnetcdf=/fusion/group/climate/software/pnetcdf/parallel-netcdf-1.2.0/install
> --with-netcdf=/fusion/group/climate/software/netcdf/netcdf-4.1.2-parallel/install
> --with-hdf5=/fusion/group/climate/software/hdf5/hdf5-1.8.6-parallel/install
> --with-zlib=/fusion/group/climate/software/zlib/zlib-1.2.5/install
> --with-szip=/fusion/group/climate/software/szip/szip-2.1/install
> --enable-optimize --disable-fortran
> CC=/soft/mvapich2/1.4.1-intel-11.1.064/bin/mpicc
> CXX=/soft/mvapich2/1.4.1-intel-11.1.064/bin/mpicxx
> Error messages:
> make[5]: Entering directory
> `/fusion/gpfs/home/xbxu/parvis/moab-performance/src/parallel'
> /bin/sh ../../libtool --tag=CXX --mode=compile
> /soft/mvapich2/1.4.1-intel-11.1.064/bin/mpicxx -DHAVE_CONFIG_H -I.
> -I../.. -I../../src/moab -I../../src
> -I/fusion/group/climate/software/pnetcdf/parallel-netcdf-1.2.0/install/include
> -I/fusion/group/climate/software/netcdf/netcdf-4.1.2-parallel/install/include
> -I/fusion/group/climate/software/hdf5/hdf5-1.8.6-parallel/install/include
> -isystem
> -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION
> -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DUSE_MPI -DHDF5_FILE
> -DHDF5_PARALLEL -DNETCDF_FILE -DPNETCDF_FILE -DIS_BUILDING_MB
> -DSRCDIR=. -I./.. -I.. -I./../io -I./../io/mhdf/include -Wall -wd981
> -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -MT ParallelComm.lo -MD -MP -MF
> .deps/ParallelComm.Tpo -c -o ParallelComm.lo ParallelComm.cpp
> libtool: compile: /soft/mvapich2/1.4.1-intel-11.1.064/bin/mpicxx
> -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src
> -isystem
> .deps/ParallelComm.Tpo -c ParallelComm.cpp -o ParallelComm.o
> SharedSetData.hpp(136): error: identifier "less_vect_indr" is
> undefined
> ParallelComm.cpp(6868): remark #869: parameter "create_if_missing" was
> never referenced
> bool create_if_missing)
> errmem.h(52): remark #177: function "buffer_reserve_" was declared but
> never referenced
> static void buffer_reserve_(buffer *b, size_t min, const char *file)
> tuple_list.h(62): remark #177: function "tuple_list_grow" was declared
> but never referenced
> static void tuple_list_grow(tuple_list *tl)
> compilation aborted for ParallelComm.cpp (code 2)
> Xiabing
