[MOAB-dev] Make check failure (5143)
Xiabing Xu
xbxu at mcs.anl.gov
Thu Sep 1 15:02:16 CDT 2011
Get a different error.
make[1]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/examples/itaps'
make FindConnectF TagIterateC TagIterateF
make[2]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/examples/itaps'
PPF77 FindConnectF.o
In file FindConnectF.F:29
call iMesh_load(%VAL(mesh), %VAL(0), "125hex.vtk", "", ierr)
1
Error: Syntax error in argument list at (1)
In file FindConnectF.F:33
call iMesh_getEntities(%VAL(mesh), %VAL(0), %VAL(iBase_REGION),
1
In file FindConnectF.F:43
call iMesh_getEntAdj(%VAL(mesh), %VAL(ents(i)),
1
In file FindConnectF.F:56
call iMesh_getEntArrAdj(%VAL(mesh), %VAL(rpents),
1
In file FindConnectF.F:72
call iMesh_dtor(%VAL(mesh), ierr)
1
make[2]: *** [FindConnectF.o] Error 1
make[2]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/examples/itaps'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/examples/itaps'
make: *** [check-recursive] Error 1
Xiabing
On Sep 1, 2011, at 2:50 PM, Jason Kraftcheck wrote:
> Please try the changes I just checked in (r5146)
> - jason
> On 09/01/2011 02:36 PM, Xiabing Xu wrote:
>> On Sep 1, 2011, at 2:33 PM, Jason Kraftcheck wrote:
>>> On 09/01/2011 02:09 PM, Xiabing Xu wrote:
>>>> [xbxu at flogin1 ~]$ which gfortran
>>>> /usr/bin/gfortran
>>>> [xbxu at flogin1 ~]$ gfortran --version
>>>> GNU Fortran (GCC) 4.1.2 20080704 (Red Hat 4.1.2-50)
>>>> Copyright (C) 2007 Free Software Foundation, Inc.
>>>> It is not g77.
>>> Please run the following three commands and send the resulting PP4.1 file to me:
>>> touch empty.F
>>> gfortran -E -dM empty.F >PP4.1
>>> rm empty.F
>>> thanks,
>>> - jason
>> That is the same command I used to get the macro list.
>> #define __DBL_MIN_EXP__ (-1021)
>> #define __FLT_MIN__ 1.17549435e-38F
>> #define __CHAR_BIT__ 8
>> #define __WCHAR_MAX__ 2147483647
>> #define __DBL_DENORM_MIN__ 4.9406564584124654e-324
>> #define __FLT_EVAL_METHOD__ 0
>> #define __DBL_MIN_10_EXP__ (-307)
>> #define __FINITE_MATH_ONLY__ 0
>> #define __SHRT_MAX__ 32767
>> #define __LDBL_MAX__ 1.18973149535723176502e+4932L
>> #define __UINTMAX_TYPE__ long unsigned int
>> #define __linux 1
>> #define __unix 1
>> #define __linux__ 1
>> #define __SCHAR_MAX__ 127
>> #define __USER_LABEL_PREFIX__
>> #define __STDC_HOSTED__ 1
>> #define __DBL_DIG__ 15
>> #define __FLT_EPSILON__ 1.19209290e-7F
>> #define __LDBL_MIN__ 3.36210314311209350626e-4932L
>> #define __unix__ 1
>> #define __DECIMAL_DIG__ 21
>> #define __gnu_linux__ 1
>> #define __LDBL_HAS_QUIET_NAN__ 1
>> #define __GNUC__ 4
>> #define __MMX__ 1
>> #define __DBL_MAX__ 1.7976931348623157e+308
>> #define __DBL_HAS_INFINITY__ 1
>> #define __DBL_MAX_EXP__ 1024
>> #define __SSE2_MATH__ 1
>> #define __amd64 1
>> #define __LONG_LONG_MAX__ 9223372036854775807LL
>> #define __GXX_ABI_VERSION 1002
>> #define __FLT_MIN_EXP__ (-125)
>> #define __x86_64 1
>> #define __DBL_MIN__ 2.2250738585072014e-308
>> #define __LP64__ 1
>> #define __DBL_HAS_QUIET_NAN__ 1
>> #define __REGISTER_PREFIX__
>> #define __NO_INLINE__ 1
>> #define __FLT_MANT_DIG__ 24
>> #define __VERSION__ "4.1.2 20080704 (Red Hat 4.1.2-50)"
>> #define unix 1
>> #define __SIZE_TYPE__ long unsigned int
>> #define __ELF__ 1
>> #define __FLT_RADIX__ 2
>> #define __LDBL_EPSILON__ 1.08420217248550443401e-19L
>> #define __GNUC_RH_RELEASE__ 50
>> #define __SSE_MATH__ 1
>> #define __k8 1
>> #define __LDBL_DIG__ 18
>> #define __x86_64__ 1
>> #define __FLT_HAS_QUIET_NAN__ 1
>> #define __FLT_MAX_10_EXP__ 38
>> #define __LONG_MAX__ 9223372036854775807L
>> #define __FLT_HAS_INFINITY__ 1
>> #define linux 1
>> #define __LDBL_MANT_DIG__ 64
>> #define __k8__ 1
>> #define __WCHAR_TYPE__ int
>> #define _LANGUAGE_FORTRAN 1
>> #define __FLT_DIG__ 6
>> #define __INT_MAX__ 2147483647
>> #define __FLT_MAX_EXP__ 128
>> #define __DBL_MANT_DIG__ 53
>> #define __WINT_TYPE__ unsigned int
>> #define __SSE__ 1
>> #define __LDBL_MIN_EXP__ (-16381)
>> #define __amd64__ 1
>> #define __LDBL_MAX_EXP__ 16384
>> #define __LDBL_MAX_10_EXP__ 4932
>> #define __DBL_EPSILON__ 2.2204460492503131e-16
>> #define _LP64 1
>> #define __GNUC_PATCHLEVEL__ 2
>> #define __LDBL_HAS_INFINITY__ 1
>> #define __INTMAX_MAX__ 9223372036854775807L
>> #define __FLT_DENORM_MIN__ 1.40129846e-45F
>> #define __FLT_MAX__ 3.40282347e+38F
>> #define __SSE2__ 1
>> #define __FLT_MIN_10_EXP__ (-37)
>> #define __INTMAX_TYPE__ long int
>> #define __GNUC_MINOR__ 1
>> #define __DBL_MAX_10_EXP__ 308
>> #define __LDBL_DENORM_MIN__ 3.64519953188247460253e-4951L
>> #define __PTRDIFF_TYPE__ long int
>> #define __LDBL_MIN_10_EXP__ (-4931)
>> #define __GNUC_GNU_INLINE__ 1
>> Xiabing
> "A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
