[MOAB-dev] Make check failure (5143)
Jason Kraftcheck
kraftche at cae.wisc.edu
Thu Sep 1 14:50:53 CDT 2011
Please try the changes I just checked in (r5146)
- jason
On 09/01/2011 02:36 PM, Xiabing Xu wrote:
> On Sep 1, 2011, at 2:33 PM, Jason Kraftcheck wrote:
>> On 09/01/2011 02:09 PM, Xiabing Xu wrote:
>>> [xbxu at flogin1 ~]$ which gfortran
>>> /usr/bin/gfortran
>>> [xbxu at flogin1 ~]$ gfortran --version
>>> GNU Fortran (GCC) 4.1.2 20080704 (Red Hat 4.1.2-50)
>>> Copyright (C) 2007 Free Software Foundation, Inc.
>>> It is not g77.
>> Please run the following three commands and send the resulting PP4.1 file to me:
>> touch empty.F
>> gfortran -E -dM empty.F >PP4.1
>> rm empty.F
>> thanks,
>> - jason
> That is the same command I used to get the macro list.
> #define __DBL_MIN_EXP__ (-1021)
> #define __FLT_MIN__ 1.17549435e-38F
> #define __CHAR_BIT__ 8
> #define __WCHAR_MAX__ 2147483647
> #define __DBL_DENORM_MIN__ 4.9406564584124654e-324
> #define __FLT_EVAL_METHOD__ 0
> #define __DBL_MIN_10_EXP__ (-307)
> #define __FINITE_MATH_ONLY__ 0
> #define __SHRT_MAX__ 32767
> #define __LDBL_MAX__ 1.18973149535723176502e+4932L
> #define __UINTMAX_TYPE__ long unsigned int
> #define __linux 1
> #define __unix 1
> #define __linux__ 1
> #define __SCHAR_MAX__ 127
> #define __USER_LABEL_PREFIX__
> #define __STDC_HOSTED__ 1
> #define __DBL_DIG__ 15
> #define __FLT_EPSILON__ 1.19209290e-7F
> #define __LDBL_MIN__ 3.36210314311209350626e-4932L
> #define __unix__ 1
> #define __DECIMAL_DIG__ 21
> #define __gnu_linux__ 1
> #define __LDBL_HAS_QUIET_NAN__ 1
> #define __GNUC__ 4
> #define __MMX__ 1
> #define __DBL_MAX__ 1.7976931348623157e+308
> #define __DBL_HAS_INFINITY__ 1
> #define __DBL_MAX_EXP__ 1024
> #define __SSE2_MATH__ 1
> #define __amd64 1
> #define __LONG_LONG_MAX__ 9223372036854775807LL
> #define __GXX_ABI_VERSION 1002
> #define __FLT_MIN_EXP__ (-125)
> #define __x86_64 1
> #define __DBL_MIN__ 2.2250738585072014e-308
> #define __LP64__ 1
> #define __DBL_HAS_QUIET_NAN__ 1
> #define __REGISTER_PREFIX__
> #define __NO_INLINE__ 1
> #define __FLT_MANT_DIG__ 24
> #define __VERSION__ "4.1.2 20080704 (Red Hat 4.1.2-50)"
> #define unix 1
> #define __SIZE_TYPE__ long unsigned int
> #define __ELF__ 1
> #define __FLT_RADIX__ 2
> #define __LDBL_EPSILON__ 1.08420217248550443401e-19L
> #define __GNUC_RH_RELEASE__ 50
> #define __SSE_MATH__ 1
> #define __k8 1
> #define __LDBL_DIG__ 18
> #define __x86_64__ 1
> #define __FLT_HAS_QUIET_NAN__ 1
> #define __FLT_MAX_10_EXP__ 38
> #define __LONG_MAX__ 9223372036854775807L
> #define __FLT_HAS_INFINITY__ 1
> #define linux 1
> #define __LDBL_MANT_DIG__ 64
> #define __k8__ 1
> #define __WCHAR_TYPE__ int
> #define _LANGUAGE_FORTRAN 1
> #define __FLT_DIG__ 6
> #define __INT_MAX__ 2147483647
> #define __FLT_MAX_EXP__ 128
> #define __DBL_MANT_DIG__ 53
> #define __WINT_TYPE__ unsigned int
> #define __SSE__ 1
> #define __LDBL_MIN_EXP__ (-16381)
> #define __amd64__ 1
> #define __LDBL_MAX_EXP__ 16384
> #define __LDBL_MAX_10_EXP__ 4932
> #define __DBL_EPSILON__ 2.2204460492503131e-16
> #define _LP64 1
> #define __GNUC_PATCHLEVEL__ 2
> #define __LDBL_HAS_INFINITY__ 1
> #define __INTMAX_MAX__ 9223372036854775807L
> #define __FLT_DENORM_MIN__ 1.40129846e-45F
> #define __FLT_MAX__ 3.40282347e+38F
> #define __SSE2__ 1
> #define __FLT_MIN_10_EXP__ (-37)
> #define __INTMAX_TYPE__ long int
> #define __GNUC_MINOR__ 1
> #define __DBL_MAX_10_EXP__ 308
> #define __LDBL_DENORM_MIN__ 3.64519953188247460253e-4951L
> #define __PTRDIFF_TYPE__ long int
> #define __LDBL_MIN_10_EXP__ (-4931)
> #define __GNUC_GNU_INLINE__ 1
> Xiabing
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
