[MOAB-dev] Make check failure (5143)
Jason Kraftcheck kraftche at cae.wisc.edu
Thu Sep 1 15:05:27 CDT 2011
On 09/01/2011 03:02 PM, Xiabing Xu wrote:
> Get a different error.
Well, the first problem seems to be fixed.
This new problem might mean that gfortran 4.1 is just too old to use (e.g.
it doesn't understand the %VAL syntax for passing variables by value to a C
function.)  You'll have to ask someone who knows more about it than I.
Do you need Fortran support?  You could avoid all of this by configuring
MOAB with --disable-fortran.
- jason
> make[1]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/examples/itaps'
> make  FindConnectF TagIterateC TagIterateF
> make[2]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/examples/itaps'
>   PPF77  FindConnectF.o
>  In file FindConnectF.F:29
>       call iMesh_load(%VAL(mesh), %VAL(0), "125hex.vtk", "", ierr)
>                      1
> Error: Syntax error in argument list at (1)
>  In file FindConnectF.F:33
>       call iMesh_getEntities(%VAL(mesh), %VAL(0), %VAL(iBase_REGION),
>                             1
>  In file FindConnectF.F:43
>          call iMesh_getEntAdj(%VAL(mesh), %VAL(ents(i)),
>                              1
>  In file FindConnectF.F:56
>       call iMesh_getEntArrAdj(%VAL(mesh), %VAL(rpents),
>                              1
>  In file FindConnectF.F:72
>       call iMesh_dtor(%VAL(mesh), ierr)
>                      1
> make[2]: *** [FindConnectF.o] Error 1
> make[2]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/examples/itaps'
> make[1]: *** [check-am] Error 2
> make[1]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/examples/itaps'
> make: *** [check-recursive] Error 1
> Xiabing
