[MOAB-dev] Make check failure (5143)
Xiabing Xu xbxu at mcs.anl.gov
Thu Sep 1 14:36:21 CDT 2011
On Sep 1, 2011, at 2:33 PM, Jason Kraftcheck wrote:
> On 09/01/2011 02:09 PM, Xiabing Xu wrote:
>> [xbxu at flogin1 ~]$ which gfortran
>> /usr/bin/gfortran
>> [xbxu at flogin1 ~]$ gfortran --version
>> GNU Fortran (GCC) 4.1.2 20080704 (Red Hat 4.1.2-50)
>> Copyright (C) 2007 Free Software Foundation, Inc.
>> It is not g77.
> Please run the following three commands and send the resulting PP4.1 file to me:
> touch empty.F
> gfortran -E -dM empty.F >PP4.1
> rm empty.F
> thanks,
> - jason
That is the same command I used to get the macro list.
#define __DBL_MIN_EXP__ (-1021)
#define __FLT_MIN__ 1.17549435e-38F
#define __CHAR_BIT__ 8
#define __WCHAR_MAX__ 2147483647
#define __DBL_DENORM_MIN__ 4.9406564584124654e-324
#define __FLT_EVAL_METHOD__ 0
#define __DBL_MIN_10_EXP__ (-307)
#define __FINITE_MATH_ONLY__ 0
#define __SHRT_MAX__ 32767
#define __LDBL_MAX__ 1.18973149535723176502e+4932L
#define __UINTMAX_TYPE__ long unsigned int
#define __linux 1
#define __unix 1
#define __linux__ 1
#define __SCHAR_MAX__ 127
#define __USER_LABEL_PREFIX__
#define __STDC_HOSTED__ 1
#define __DBL_DIG__ 15
#define __FLT_EPSILON__ 1.19209290e-7F
#define __LDBL_MIN__ 3.36210314311209350626e-4932L
#define __unix__ 1
#define __DECIMAL_DIG__ 21
#define __gnu_linux__ 1
#define __LDBL_HAS_QUIET_NAN__ 1
#define __GNUC__ 4
#define __MMX__ 1
#define __DBL_MAX__ 1.7976931348623157e+308
#define __DBL_HAS_INFINITY__ 1
#define __DBL_MAX_EXP__ 1024
#define __SSE2_MATH__ 1
#define __amd64 1
#define __LONG_LONG_MAX__ 9223372036854775807LL
#define __GXX_ABI_VERSION 1002
#define __FLT_MIN_EXP__ (-125)
#define __x86_64 1
#define __DBL_MIN__ 2.2250738585072014e-308
#define __LP64__ 1
#define __DBL_HAS_QUIET_NAN__ 1
#define __REGISTER_PREFIX__
#define __NO_INLINE__ 1
#define __FLT_MANT_DIG__ 24
#define __VERSION__ "4.1.2 20080704 (Red Hat 4.1.2-50)"
#define unix 1
#define __SIZE_TYPE__ long unsigned int
#define __ELF__ 1
#define __FLT_RADIX__ 2
#define __LDBL_EPSILON__ 1.08420217248550443401e-19L
#define __GNUC_RH_RELEASE__ 50
#define __SSE_MATH__ 1
#define __k8 1
#define __LDBL_DIG__ 18
#define __x86_64__ 1
#define __FLT_HAS_QUIET_NAN__ 1
#define __FLT_MAX_10_EXP__ 38
#define __LONG_MAX__ 9223372036854775807L
#define __FLT_HAS_INFINITY__ 1
#define linux 1
#define __LDBL_MANT_DIG__ 64
#define __k8__ 1
#define __WCHAR_TYPE__ int
#define _LANGUAGE_FORTRAN 1
#define __FLT_DIG__ 6
#define __INT_MAX__ 2147483647
#define __FLT_MAX_EXP__ 128
#define __DBL_MANT_DIG__ 53
#define __WINT_TYPE__ unsigned int
#define __SSE__ 1
#define __LDBL_MIN_EXP__ (-16381)
#define __amd64__ 1
#define __LDBL_MAX_EXP__ 16384
#define __LDBL_MAX_10_EXP__ 4932
#define __DBL_EPSILON__ 2.2204460492503131e-16
#define _LP64 1
#define __GNUC_PATCHLEVEL__ 2
#define __LDBL_HAS_INFINITY__ 1
#define __INTMAX_MAX__ 9223372036854775807L
#define __FLT_DENORM_MIN__ 1.40129846e-45F
#define __FLT_MAX__ 3.40282347e+38F
#define __SSE2__ 1
#define __FLT_MIN_10_EXP__ (-37)
#define __INTMAX_TYPE__ long int
#define __GNUC_MINOR__ 1
#define __DBL_MAX_10_EXP__ 308
#define __LDBL_DENORM_MIN__ 3.64519953188247460253e-4951L
#define __PTRDIFF_TYPE__ long int
#define __LDBL_MIN_10_EXP__ (-4931)
#define __GNUC_GNU_INLINE__ 1
Xiabing
