[MOAB-dev] Issues with default gfortran compiler on fusion
Xiabing Xu
xbxu at mcs.anl.gov
Thu Sep 1 14:49:19 CDT 2011
I have a problem working with a library requiring a predefined macro __SIZEOF_SIZE_T__ on fusion.
By running the following command, I can get a list of predefined macros.
touch foo.F; gfortran -E -dM foo.F
However, the __SIZEOF_SIZE_T__ is missing.
According to the gcc manual, the __SIZEOF_SIZE_T__ should be defined in common cases.
http://gcc.gnu.org/onlinedocs/cpp/Common-Predefined-Macros.html
Is there any specific reason that this macro is disabled? Or is it because gfortran compiler used on fusion is too old?
Xiabing
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110901/0c0e785d/attachment.htm>
