[MOAB-dev] r5146 - in MOAB/trunk/itaps: . igeom imesh
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Sep 1 14:41:26 CDT 2011
Author: kraftche
Date: 2011-09-01 14:41:26 -0500 (Thu, 01 Sep 2011)
New Revision: 5146
Modified:
   MOAB/trunk/itaps/iBase_f.h
   MOAB/trunk/itaps/igeom/iGeom_f.h
   MOAB/trunk/itaps/imesh/iMesh_f.h
Log:
Various fixes to Fortran ITAPS headers:
 o special logic for gfortran-4.2 and earlier
 o s/PTRSIZE/POINTER_SIZE/ to be consistent with official ITAPS headers
 o s/IMESH_HANDLE_T/IBASE_HANDLE_T/ because it is defined in iBase_f.h
 o detect BGP and BGQ specially, as we don't have a way to detect IBM Fortran
 o use IBASE_HANDLE_T to define handles in iGeom_f.h
Modified: MOAB/trunk/itaps/iBase_f.h
--- MOAB/trunk/itaps/iBase_f.h	2011-08-31 21:53:33 UTC (rev 5145)
+++ MOAB/trunk/itaps/iBase_f.h	2011-09-01 19:41:26 UTC (rev 5146)
@@ -1,29 +1,37 @@
 #ifndef IBASE_F_H
 #define IBASE_F_H
-#ifdef PTRSIZE
-c user-defined override
-#  define IMESH_HANDLE_T INTEGER*PTRSIZE
+#ifdef POINTER_SIZE
+c  user-defined override
+#  define IBASE_HANDLE_T INTEGER*POINTER_SIZE
 #elif defined(__SIZEOF_SIZE_T__)
-c gfortran
-#  define IMESH_HANDLE_T integer*__SIZEOF_SIZE_T__
+c  gfortran
+#  define IBASE_HANDLE_T integer*__SIZEOF_SIZE_T__
+#elif defined(__GNUC__) && defined (_LANGUAGE_FORTRAN)
+c  gfortran 4.2 and earlier
+#  ifdef _LP64
+#    define IBASE_HANDLE_T integer*8
+#  else
+c    NOTE: not integer*4 (see meaning of _LP64 in GNU docs)
+#  endif
 #elif defined(__INTEL_COMPILER)
 #  ifdef __X86_64
-#    define IMESH_HANDLE_T integer*8
 #  else
-#    define IMESH_HANDLE_T integer*4
+#    define IBASE_HANDLE_T integer*4
 #  endif
-#elif defined(__XLCPP__)
-c This doesn't work.  I cannot find a pre-defined macro to identify IBM XL Fortran
+#elif defined(__XLCPP__) || defined(__bgp__) || defined(__bgq__)
+c  __XLCPP__ doesn't work for IBM.  AT least make things work for BGP and BGQ
         USE, INTRINSIC :: ISO_C_BINDING
-#  define IMESH_HANDLE_T C_PTR
+#  define IBASE_HANDLE_T C_PTR
 #else
-#  error "Unknown compiler.  Please define PTRSIZE."
+#  error "Unknown compiler.  Please define POINTER_SIZE."
 #endif
-#define iBase_EntityHandle IMESH_HANDLE_T
-#define iBase_EntitySetHandle IMESH_HANDLE_T
-#define iBase_TagHandle IMESH_HANDLE_T
+#define iBase_EntityHandle IBASE_HANDLE_T
