[MOAB-dev] [lcrc-support #85171] Issues with default gfortran	compiler on fusion
    Jason Hedden
    Jhedden at mcs.anl.gov
    Thu Sep  1 15:08:31 CDT 2011
Xiabing,
I'm not sure off hand why size_t is not defined in the default 4.1 version, but it is defined in our 4.4 build of GCC.
$soft add +gcc-4.4
$ touch foo.F; gfortran -E -dM foo.F | grep -i SIZE_T
#define __SIZEOF_SIZE_T__ 8
To use in your environment add the +gcc-4.4 softenv key you your ~/.soft file. For information on using softenv on Fusion please refer to http://www.lcrc.anl.gov/info/Software/Softenv
Jason Hedden
On Sep 1, 2011, at 2:49 PM, Xiabing Xu wrote:
> I have a problem working with a library requiring a predefined macro __SIZEOF_SIZE_T__ on fusion.
> By running the following command, I can get a list of predefined macros.
> However, the __SIZEOF_SIZE_T__ is missing.
> According to the gcc manual, the __SIZEOF_SIZE_T__ should be defined in common cases.
> http://gcc.gnu.org/onlinedocs/cpp/Common-Predefined-Macros.html
> Is there any specific reason that this macro is disabled? Or is it because gfortran compiler used on fusion is too old?
> Thanks,
> Xiabing
