[MOAB-dev] Make Check Failure
Iulian Grindeanu
iulian at mcs.anl.gov
Tue Aug 30 16:24:16 CDT 2011
The error is related to the MPI initialization you mentioned this morning
$ obb_test
MOAB 4.1.0pre
No file(s) specified.
Using default file "../../MeshFiles/unittest/3k-tri-sphere.vtk"
Using default file "../../MeshFiles/unittest/3k-tri-cube.h5m"
Building tree from 2970 2D elements
No errors detected.
Attempting to use an MPI routine after finalizing MPICH
----- Original Message -----
> What are your configure options?
> - tim
> On 08/30/2011 03:54 PM, Xiabing Xu wrote:
> > I was compiling trunk (5140) with --enable-debug option.
> > Error messages:
> > Making check in obb
> > make[2]: Entering directory
> > `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
> > make obb_test obb_time obb_tree_tool
> > make[3]: Entering directory
> > CXX obb_test.o
> > CXXLD obb_test
> > CXX obb_time.o
> > CXXLD obb_time
> > CXX obb_tree_tool.o
> > CXXLD obb_tree_tool
> > make[3]: Leaving directory
> > make check-TESTS
> > make[4]: Entering directory
> > FAIL: obb_test
> > 1 of 1 test failed
> > See test/obb/test-suite.log
> > make[4]: *** [test-suite.log] Error 1
> > make[4]: Leaving directory
> > make[3]: *** [check-TESTS] Error 2
> > make[2]: *** [check-am] Error 2
> > make[2]: Leaving directory
> > make[1]: *** [check-recursive] Error 1
> > make[1]: Leaving directory
> > `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test'
> > make: *** [check-recursive] Error 1
> > Xiabing
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
