[MOAB-dev] Make Check Failure
Steve Jackson sjackson at cae.wisc.edu
Tue Aug 30 16:26:10 CDT 2011
The obb_test program creates and destroys multiple MOAB instances, so this is probably related to the MPI initialization issue we discussed in this morning's meeting.
(I see Iulian figured this out ahed of me.  :)
~S
On Aug 30, 2011, at 16:20 , Tim Tautges wrote:
> What are your configure options?
> - tim
> On 08/30/2011 03:54 PM, Xiabing Xu wrote:
>> I was compiling trunk (5140) with --enable-debug option.
>> Error messages:
>> Making check in obb
>> make[2]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
>> make  obb_test obb_time obb_tree_tool
>> make[3]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
>>   CXX    obb_test.o
>>   CXXLD  obb_test
>>   CXX    obb_time.o
>>   CXXLD  obb_time
>>   CXX    obb_tree_tool.o
>>   CXXLD  obb_tree_tool
>> make[3]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
>> make  check-TESTS
>> make[4]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
>> FAIL: obb_test
>> 1 of 1 test failed
>> See test/obb/test-suite.log
>> make[4]: *** [test-suite.log] Error 1
>> make[4]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
>> make[3]: *** [check-TESTS] Error 2
>> make[2]: *** [check-am] Error 2
>> make[2]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test/obb'
>> make[1]: *** [check-recursive] Error 1
>> make[1]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build-check/test'
>> make: *** [check-recursive] Error 1
>> Xiabing
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>         phone: (608) 263-8485      1500 Engineering Dr.
>           fax: (608) 263-4499      Madison, WI 53706
